| Cvrguy |
Jul 10 2026, 01:59 PM
Newbie ![]() Group: Members Posts: 34 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
Where is the cylinder head temp sensor located on a 2.0l? What the wire color coding?
| JamesM |
Jul 10 2026, 03:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,271 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Where is the cylinder head temp sensor located on a 2.0l? What the wire color coding? Are you looking for the CHT sensor for the injection system or a CHT censor for a gauge? All CHT gauges are aftermarket so cant say for sure. CHT sensor for the fuel injection system is installed through a hole in the cooling tin to the right of the #3 spark plug. Wire on the harness side is white (as are all wires in the injection harness) Wire for the sensor itself I have seen be multiple different colors. Usually black, but I have seen grey, as well as various patch jobs. Its hard to miss though as it will be the only single wire coming through that hole in the tin. |
Lo-Fi Version | Time is now: 10th July 2026 - 04:06 PM |
