| jfort |
Jul 12 2026, 02:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
New (refurbished) and a new headliner. I thought I had used a good spray adhesive (3M?) but the headliner keeps falling. What’s the trick?
| mepstein |
Jul 12 2026, 02:46 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,809 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Higher strength 3m. There are a couple different levels.
| wonkipop |
Jul 12 2026, 02:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,604 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
i use this stuff these days for contact adhesive applications.
its very good. better than 3M i have found. not that 3M is bad, but this gear appears to be that little bit better. but its more $ you got to follow the directions. the usual drill. clean both surfaces thoroughly. degrease as well. metholated spirits or iso propyl alc for that final clean. then get the timing right on the tackiness. the stuff i use comes in a can and is not sprayed on. i have never seen it in a spray can form. you got to use a brush. its almost impossible to clean the brush after use - so i have a packet of disposable brushes. ![]() |
| aharder |
Jul 12 2026, 04:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,037 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region
Higher strength 3m. There are a couple different levels. (IMG:style_emoticons/default/agree.gif) I used The High Strength 90 |
Lo-Fi Version | Time is now: 12th July 2026 - 07:08 PM |
