> fuel pump power failure
Cvrguy
post Jul 13 2026, 11:57 AM
I have a '73 914 2.0 with a well sorted D-jet system. Driving the other day, I came to a stop and the engine died. When I tried to restart it, I didn't hear the fuel pump cycle when the key was turned. Sure enough, when I checked with the multimeter, no voltage to the pump when the key was turned. I had previously relocated the fuel pump to the front, extending the power lead from the rear to the front through the center tunnel.
Troubleshooting so far: 12v directly to the pump shows it running fine, correct continuity from the rear to the front on the power lead, replaced the relay. As far as I can determine, the problem lies between the circuit board and the original 12v lead. I had previously replace the circuit board and both multi-pin connectors. The ground point for both the circuit board and the fuel pump are perfect. I replaced the ignition switch a few months ago as well
Is there another common failure point that I can investigate?
Replies(1 - 4)
JamesM
post Jul 13 2026, 12:03 PM
QUOTE(Cvrguy @ Jul 13 2026, 09:57 AM) *
There are a TON of failure points in that circuit, most are in or around the relay board.
Jeff Bowlsby has a document that goes over troubleshooting all of them, ill see if I can dig it up. I find its usually due to one of the crimped traces in the relay board connection losing conductivity though.
Edit: Link below
https://bowlsby.net/914/Classic/zTN_FI_FPChecklist2.pdf
Another point to note is that often the trace falures in the relay board will often only fail under certian heat or pressure conditions so the board with bench test out fine but fail when connectors are installed or after 10 minutes of driving and things get hot.
friethmiller
post Jul 13 2026, 12:06 PM
I had this problem once. It was the connection at the battery. I found this out after pushing the car up the remainder of the hill it stranded me on. (IMG:style_emoticons/default/chair.gif)
porschetub
post Jul 13 2026, 01:55 PM
QUOTE(friethmiller @ Jul 14 2026, 06:06 AM) *
My fault was the power control relay ,changed that and all good ,cheers.
Cvrguy
post Jul 13 2026, 02:04 PM
Thanks so much for the checklist from Jeff. Just what I was looking for!
- Lo-Fi Version Time is now: 13th July 2026 - 06:45 PM
