| StarBear |
Jul 16 2026, 02:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,367 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Was going to post this in the prior thread but most of seems to have disappeared.
Anyway: 1. Got the old incorrect hose dyed and inserted through the grommet, so it looks ok. But… 2. Looking under the gas cap, the line is crimped, see pic, so no vapor flow (tried…). Question: is this normal? Part of a recall notice done ages ago by dealer or by a mechanic somewhere along the time path? I’m sure I didn’t do it. |
| Shivers |
Jul 16 2026, 05:18 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,589 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| StarBear |
Jul 17 2026, 05:42 AM
Interesting!
@wonkipop ? @jeffbowlsby ? I wonder then if it’s crimped then should the hose be connected to the nipple on the expansion tank? Could it create a vacuum as the gas is used, leading to a very bad gas tank inversion? Maybe leave the hose off that nipple to prevent vacuum in the tank? (IMG:style_emoticons/default/confused24.gif) |
| 76-914 |
Jul 17 2026, 07:46 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,964 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Probably just to keep a large amount of gas from entering the system if overfilled or when sloshed from spirited driving. (IMG:style_emoticons/default/confused24.gif)
| StarBear |
Jul 17 2026, 08:44 AM
Probably just to keep a large amount of gas from entering the system if overfilled or when sloshed from spirited driving. (IMG:style_emoticons/default/confused24.gif) But if crimped closed it can’t serve any function. Weird….. |
| JeffBowlsby |
Jul 17 2026, 10:07 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,356 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
| StarBear |
Jul 17 2026, 11:50 AM
Yes; mine seems air tight. Blew into long end of the hose; it filled then blew back when released. Could see where it might be lightly crimped to keep out debris but not full crimped. Still learning about the car even after 52 years…. |
| StarBear |
Jul 17 2026, 12:17 PM
Checked with fellow teener here. His is crimped too but has a bit of flow to it. Maybe my crimp just has 52 years of gunk in it. To the bat garage, Robin!!
| StarBear |
Jul 17 2026, 12:46 PM
Success! (IMG:style_emoticons/default/biggrin.gif)
Put a drop of penetrating oil on the crimp, a bit of brass wire brush the a tad of puncturing with a small vise grip followed by a short wire from the hose side of the nipple. Now have just a bit of flow for any vapor equalization. School’s out!!! (IMG:style_emoticons/default/piratenanner.gif) |
| Cairo94507 |
Jul 18 2026, 12:55 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,766 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I happened to be in the garage working on my car so I snapped a couple pictures of that pipe in the filler neck. Mine looks unmolested and is kind of flattened down too. (IMG:style_emoticons/default/beerchug.gif)
| StarBear |
Jul 18 2026, 01:27 PM
I happened to be in the garage working on my car so I snapped a couple pictures of that pipe in the filler neck. Mine looks unmolested and is kind of flattened down too. (IMG:style_emoticons/default/beerchug.gif) Thanks! Hose nice and tight, too. |
| DC_neun_vierzehn |
Jul 18 2026, 03:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 677 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
Checked mine (‘73 2.0) and it looks crimped as well. Did not do a blow test yet tho.
| wonkipop |
Jul 18 2026, 08:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,714 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
yeah mine's crimped.
its not there for fluid to pass through. its for air mixed with vapors. fuel expands with heat. and - as you also note its to provide pressure equalisation as the tank draws down, air is drawn in via the charcoal can route, through the expansion tank and through that little crimped tube. probably a good thing you cleaned it. sounded like it was clogged. |
Lo-Fi Version | Time is now: 20th September 2026 - 09:15 AM |
