| scott_in_nh |
Jul 27 2026, 07:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 816 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I'm trying to get everything together that I will need to finally drop the motor so I won't have any excuses left to keep kicking the can....
I need a new floor jack anyway, and I want to buy the Tangerine lifting plate. Any advantages/disadvantages of using the post model vs the Allen screw model? What size and type of jack? limited use so Harbor Freight models or similar are fine. What is the best height for dropping the motor? The car will be level unless there is a reason for it not to be. Thanks |
| Superhawk996 |
Jul 27 2026, 08:35 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,047 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Tallest Daytona jack you can get and the tangerine lift plate.
Don’t cheap out on the Jack. A good Jack makes a huge difference. I’ve done drops on everything from an el cheap K-mart two ton which was tippy and too short to a good Daytona (the snap-on knockoff). The stability of the jack makes a world of difference. ![]() And make sure you have jackstands too. Never get under a car without jackstands. |
| 930cabman |
Jul 27 2026, 09:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,824 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Tallest Daytona jack you can get and the tangerine lift plate. Don’t cheap out on the Jack. A good Jack makes a huge difference. I’ve done drops on everything from an el cheap K-mart two ton which was tippy and too short to a good Daytona (the snap-on knockoff). The stability of the jack makes a world of difference. ![]() And make sure you have jackstands too. Never get under a car without jackstands. (IMG:style_emoticons/default/agree.gif) have the exact same setup, quick, simple and works great. JACKSTANDS and make sure the chassis withstands the shake test |
| TRP |
Jul 27 2026, 09:32 AM
Member ![]() ![]() Group: Members Posts: 449 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
I have two of the Daytona jacks and the bolt through Tangerine plate. I have 1 blue and 1 gray Daytona, I wish I had the yellow, as I think it raises a little bit higher than the blue/gray ones. You want the taller jack so that you car reach the motor safely when the car is raised up in the air high enough to be able to slide the motor out.
You can sometimes time your purchase with one of the big sales and get a pretty good price on them. |
| emerygt350 |
Jul 27 2026, 10:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,733 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I always put the tires under the carr as well as the cal stands, just for extra insurance.
| johnhora |
Jul 27 2026, 10:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
Worth every $$ for doing this job....makes it so easy and safe
As mentioned above a good jack like shown that has a high lift dimension ....you want the car high enough and don't want to make the mistake of not jacking the car high enough and having the engine especially carbs hit the rear of the engine compartment when trying to take the engine out. And of course this item: https://tangerineracing.com/shop/ols/produc...gine-lift-plate |
| L-Jet914 |
Jul 27 2026, 03:39 PM
Member ![]() ![]() Group: Members Posts: 424 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I haven't pulled my own engine yet, but I use a set of QuickJack lifts to work on my vehicles.
| mepstein |
Jul 27 2026, 04:04 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,907 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I have a used tangerine plate that I need to sell. No T4’s in my garage.
| Nana's_914 |
Jul 27 2026, 04:05 PM
Member ![]() ![]() Group: Members Posts: 115 Joined: 27-October 06 From: San Diego, CA Member No.: 7,100 Region Association: Southern California |
Don't forget Wheel Chocks.
https://www.harborfreight.com/solid-rubber-...hock-96479.html |
| NARP74 |
Jul 27 2026, 04:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,567 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
AC Hydraulic has some great high lift floor jacks but they are expensive. Not in my garage, probably better for a business, not a hobbyist.
| sixaddict |
Jul 27 2026, 05:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,085 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
I have had AC Hydraulics jack for longer than I can recall.
Expensive yes but lift was highest possible and for a 6 it was necessary (to me). Pelican sells but others as well. Back when I bought it, Harbor discontinued a high lift and this was only option. |
| scott_in_nh |
Jul 28 2026, 10:48 AM
Tallest Daytona jack you can get and the tangerine lift plate. Don’t cheap out on the Jack. A good Jack makes a huge difference. I’ve done drops on everything from an el cheap K-mart two ton which was tippy and too short to a good Daytona (the snap-on knockoff). The stability of the jack makes a world of difference. And make sure you have jackstands too. Never get under a car without jackstands. Thanks, is that the tube type or bolt type? |
| scott_in_nh |
| 930cabman |
Jul 28 2026, 10:56 AM
IIRC there was some machine work involved to adapt the Tangerine plate to the HF Daytona jack
| Superhawk996 |
Jul 28 2026, 11:26 AM
IIRC there was some machine work involved to adapt the Tangerine plate to the HF Daytona jack Mine dropped right in but my Daytona is probably 8 years old so can’t speak to any recent changes they may have made. Could get measurement from Chris for his plate and verify to whatever is in stock at local HF. |
| Superhawk996 |
Jul 28 2026, 11:49 AM
Tallest Daytona jack you can get and the tangerine lift plate. Don’t cheap out on the Jack. A good Jack makes a huge difference. I’ve done drops on everything from an el cheap K-mart two ton which was tippy and too short to a good Daytona (the snap-on knockoff). The stability of the jack makes a world of difference. And make sure you have jackstands too. Never get under a car without jackstands. Thanks, is that the tube type or bolt type? ![]() Sorry can’t get tangerine plate for you - buried in storage somewhere. Talk to Chris for plate dimensions or his ability to modify to whatever jack you end up with |
| 930cabman |
Jul 28 2026, 12:18 PM
I purchased my HF Daytona jack a year or so ago and removing the pad was a chore, also had my local friendly machinist make an adapter to accommodate the plate from
Tangerine mine is not threaded as shown |
| ChrisFoley |
Jul 29 2026, 11:24 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,032 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Take your time making up your mind, Scott. (IMG:style_emoticons/default/smile.gif)
I sold my last one off the shelf a week ago and I haven't yet started assembling the new parts which arrived yesterday. The yellow jack shown accepts the standard screw-on lift plate. However, I measure the head of the big Allen screw. |
| scott_in_nh |
Jul 29 2026, 01:29 PM
Take your time making up your mind, Scott. (IMG:style_emoticons/default/smile.gif) I sold my last one off the shelf a week ago and I haven't yet started assembling the new parts which arrived yesterday. The yellow jack shown accepts the standard screw-on lift plate. However, I measure the head of the big Allen screw. Thanks Chris, I've already taken so much time starting this project due to my "2 year" restoration of my boat that took me 9 years, so another couple of weeks won't matter lol A trip to Harbor Freight with a caliper should clear it up.... |
| jim_hoyland |
Jul 29 2026, 07:20 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,130 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
(IMG:style_emoticons/default/popcorn[1].gif) Details please..,,
Lo-Fi Version | Time is now: 15th September 2026 - 02:33 PM |
