> firing order on valve adjustment, rotate rotor clockwise or counterclockwise
karmanbuilt
post Jul 28 2026, 12:57 PM
If we follow the firing order for valve adjustment, (1,4,3,2) you have to go clockwise to adjust in that order. Some topics say to go counterclockwise. Does it matter once you find #1 TDC? Also, if cylinders #1 and #3 share the same timing mark, why can't you adjust those cylinders at the same time? : confused: Be kind, I'm old (80)
Thanks
Replies(1 - 1)
emerygt350
post Jul 28 2026, 02:33 PM
Either way is fine just know where you are or just do it with the crusty method.
There are only four lobes on the cam, each shares two valves. So if the valve on one side is completely depressed, the valve on the opposite side must be loose. So rotate the engine till your valve is completely depressed as far as it will go, then adjust the opposite. So if exhaust on cylinder 4 is all the way in, exhaust on cylinder 1 must be loose and ready for adjusting. Just work your way around, not caring which stroke you are on or any of the other nonsense.
I think the easiest way to rotate the engine is to put it in 5th gear and just roll a tire. You need to block the opposite tire of course.
4 User(s) are reading this topic (3 Guests and 1 Anonymous Users)
- Lo-Fi Version Time is now: 28th July 2026 - 03:44 PM
