| robkammer |
Jul 31 2026, 03:48 PM
Robbo ![]() ![]() Group: Members Posts: 282 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
All: Working through a new motor break in period. Hit a snag where I need to run the Motor with the cart in the air, without the front mounting bracket in place. Seems the tight motor is taxing the starter, and might have ,(probably did) smoke the ignition switch.
I have two things on order, a starter relay kit, and a new switch. However, I would like to run it once more while on the lift to video the leaking oil pump. The question:with the key on, the car in the air, can I jumper the large starter contact and one of the solenoid contacts to get the starter cranking? I used to do this on Fords all of the time, a little jumper on the coil, and a screwdriver to jump the solenoid. Drive away! It took me a few times driving to realize that I needed to pull the speedo cable so my parents didn’t know I took the car. Simple times. At least now I have the key! Robbo |
| Jack Standz |
Jul 31 2026, 04:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 887 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
You can make one possiblly from spare parts you have laying around (what we did), including a piece of wire you momentarily hold from the positive side to the solenoid (where the yellow wire on ours is attached).
Or buy one for $20: https://www.amazon.com/MGI-SpeedWare-Remote...5891&sr=8-8 |
| emerygt350 |
Jul 31 2026, 04:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,694 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Yes, just grab a screwdriver and hit the top prong on the solenoid to the hot battery cable.
Lo-Fi Version | Time is now: 31st July 2026 - 06:09 PM |
