| NARP74 |
Aug 3 2026, 04:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,586 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
When I took my turn signal switch out to replace it, I had some wires that came out with it. Looks like the washer switch has been upgraded to an electrical type pump. The wires were unterminated. I need some small connectors to go though the steering housing so I can disconnect them the next time I have to replace either switch. The turn signal has already been replaced at least once, it did not have a stock one in it any more.
Should I just used small insulated spade lugs or is there a more elegant solution for two wire connections to go through the housing? |
| GregAmy |
Aug 3 2026, 04:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,722 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
I'm a big fan of using Deutsch connectors for non-OEM connections.
While true Deutsch are top notch, they require a special barrel crimper. However, there are good-quality connectors that use connectors that leverage common crimpers that work well. Example: https://www.amazon.com/DT-Connectors-Waterp...S/dp/B0CZ7K8G67 |
| NARP74 |
Aug 3 2026, 08:19 PM
I'll have to figure out if one of those will fit through the opening in the column.
| JeffBowlsby |
Aug 3 2026, 10:42 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,390 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
For your ‘74 car? It should have a plastic female multi pin connector housing on the main harness that mates with the window wiper switch.
| NARP74 |
Aug 4 2026, 08:33 AM
This is for a window washer motor mod that someone did. I am just trying to hook it up. The other connections are stock.
| NARP74 |
Aug 6 2026, 05:35 PM
Kicked the can down the road for a little while. I added some wire with butt splices and marked it and rolled it up. Too many more important projects right now. Wasn't ready to do the whole job yet.
Lo-Fi Version | Time is now: 22nd November 2026 - 08:18 PM |
