| 914xr75 |
Aug 5 2026, 12:14 PM
Member ![]() ![]() Group: Members Posts: 230 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California |
My daughter’s 73 is having a very hard time shifting into reverse and first. A couple years ago I replaced all the bushings down below, but I did not replace anything in the console area.
While going about 2 miles an hour, I can get it into first, but reverse is very difficult. I’ve got it up on jackstands right now and I’m about to put my level one mechanical eye on it. Just thought I’d throw this out in case anyone knows what I need to look for before I get down under Lil’s 914—-again. She’ll be helping me this time. |
| Jack Standz |
Aug 5 2026, 02:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 896 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Maybe the first place to look is where the front and rear shift rods connect under the rubber boot by the firewall. Is the cone screw loose? Also, check the bushing there and all the bushings back to the transmission.
| mark04usa |
Aug 5 2026, 03:00 PM
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 366 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region
Be sure that the clutch is disengaging. If out of adjustment, or if the clutch cable tube has broken loose, could be cause of your 1st/reverse problem.
Lo-Fi Version | Time is now: 5th August 2026 - 03:41 PM |
