> Weber Carb Restore Questions, Manifold preferences, Manual Choke, etc..
Literati914
post Aug 5 2026, 07:13 PM
I'm going to restore (try to) a set of Italian Weber 40idf carburetors to put on a 1.7 engine. I have two sets of manifolds... one set has a vacuum port on one runner (each side of engine), and the other has none at all. Is one type favored?
Which do I want to use, and why? - I have no idea what the vac ports would connect to. If they help even out idle, I'd want them I guess. Thoughts?
Replies(1 - 15)
dtmehall
post Aug 5 2026, 07:18 PM
what kind of distirbuter?
Literati914
post Aug 5 2026, 08:01 PM
QUOTE(dtmehall @ Aug 5 2026, 08:18 PM) *
These are bigger ports on the manifolds than typical of a vacuum port on a distributor.. (IMG:style_emoticons/default/idea.gif) But to answer the question, I have not really thought about it - I do have a Pertronix Flamethrower SVDA in a box somewhere, so probably that.
porschetub
post Aug 5 2026, 10:31 PM
the inlet manifolds you describe with the large vacuum fittings would have been used on a t4 VW bus most likely ,they are there for power brake servo so not needed the plain ones will be fine on a 914.
Pick up vacuum from one carb with the SVDA dizzy and you will be fine and block off the unused one on the other carb ,just make sure the carbs have 28mm vents and moderate jetting for a 1.7 otherwise it will run like (IMG:style_emoticons/default/stromberg.gif) ,cheers.
930cabman
post Aug 6 2026, 04:52 AM
[quote name='Literati914' date='Aug 5 2026, 07:13 PM' post='3267680']
[/quote
my first thought is, too much carbs for a 1.7?
I am running a set on my 2056 and are working very well. Too much carb volume is generally not good. Maybe source a set of early single throat carbs
so far as the rebuild process, it's like anything else, do your research, take your time, measure twice (or more) cut once
dtmehall
post Aug 6 2026, 03:28 PM
i am running 40idf's on a 1.7, and it runs great!
Literati914
post Aug 6 2026, 04:11 PM
QUOTE(porschetub @ Aug 5 2026, 11:31 PM) *
Thanks for the info.. the pic below shows the large vacuum ports I’d mentioned. So I suppose if I pull a single vacuum from my other manifolds as you suggest, I’d need to tap in a small nipple for it? - I haven’t seen that before.
Ninja
post Aug 6 2026, 04:18 PM
You will want the smallest venturis available for that.
Pierce Manifold is my go-to for Weber stuff.
They should have 27 or 28s available.
I'd start with 135 mains, 200 Airs, and 50 or 55 idles.
40 IDFs with 28 venturis are excellent for 2.0Ls with a "street" friendly motor.
Manifold ports don't matter, just make sure to cap them off.
Those might be helpful if you were going ITB fuel injection as they could form a plenum for an IAC (idle air control) valve.
Literati914
post Aug 6 2026, 04:26 PM
QUOTE(Ninja @ Aug 6 2026, 05:18 PM) *
Good real world info right there, thanks
dtmehall
post Aug 6 2026, 04:40 PM
i am running 52 idles and 125 mains
dtmehall
post Aug 6 2026, 04:41 PM
and 28 mm venturis
Literati914
post Aug 6 2026, 07:14 PM
QUOTE(dtmehall @ Aug 6 2026, 05:40 PM) *
QUOTE(dtmehall @ Aug 6 2026, 05:41 PM) *
and 28 mm venturis
(IMG:style_emoticons/default/aktion035.gif) Thanks for the specifics!
porschetub
post Aug 6 2026, 09:36 PM
QUOTE(dtmehall @ Aug 7 2026, 10:40 AM) *
I'am a Dellorto guy but that sounds about right ,28mm vents provide great vacuum signal and response to assist early transition to main jets which IMO work well on a small displacement T4 .this will work well with the svda Pertronix dizzy you have.
You will be drawing vacuum from one carb and not the manifold as you need a vacuum that is variable due to throttle position so the undrilled manifolds are your best choice as you mentioned you had a set .
Cheers.
Literati914
post Aug 7 2026, 02:24 PM
Thanks again guys!
One set has what I guess is cable controlled chokes and the other just has plates where chokes go. The set with cables, has the main cable cut... that is, I think it was cut short upon removal - I'm not even sure how/where it would lead to for manual control inside the cabin. Can someone enlighten me on that?
Our climate here in N.TX. is mainly warm, like 9 mos. a year, but we do get some really cold spells too - do I even need a choke system for almost daily use?
Sorry if these are lame questions, but I know almost nothing about Weber carbs.
porschetub
post Aug 7 2026, 03:09 PM
QUOTE(Literati914 @ Aug 8 2026, 08:24 AM) *
Thanks again guys!
Chokes aren't needed so you can save yourself that job ..more trouble than they are worth ,cheers.
dtmehall
post Aug 7 2026, 04:20 PM
no chokes on mine
- Lo-Fi Version Time is now: 20th September 2026 - 12:38 PM
