| DennisV |
Aug 16 2026, 07:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,002 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Is the only 9 mm ID fuel hose between the fuel tank and the fuel pump? The hose to the fuel rail and between the carbs is 7 mm ID?
Best I can tell from the parts catalog, this is the case. Though the hose between the fuel rail isn't given a part number. Nor is the hose on the carbs. ![]() It is counterintuitive to me that you'd supply the fuel pump with 9mm, then reduce the size that' delivering to the carbs to 7mm. Thanks. |
Lo-Fi Version | Time is now: 17th August 2026 - 12:38 PM |
