> Heat Exchanger Nut Tool, 914-6 Hex Nut
DennisV
post Aug 20 2026, 09:07 AM
What have you found or fabricated to tighten the 13 ATF hex nut on 914-6 heat exchanger passenger side? I think that's cylinder number 1.
I'm sure this is probably mechanics 101, but I'm having a hard time with it. I've tried every combination of 1/4 socket, u-joint, wobble extender, flex driver I can find. No room for a box or open end wrench as 2 sides are blocked by bracket and pipe. Nothing I've tried provides enough engagement to properly tighten it.
Replies(1 - 19)
Cairo94507
post Aug 20 2026, 09:13 AM
Michael
Hi Dennis, Yeah there is a special wrench that is bent kind of like a Z that allows you to get in there and tighten that nut with ease. Good luck, Michael (IMG:style_emoticons/default/beerchug.gif)
rudedude
post Aug 20 2026, 09:23 AM
SSI included either a 12mm or 13mm z shaped wrench with their replacement exchangers. Maybe ask around. I have used 12mm across the flats nuts and seems to make it easier.
sixnotfour
post Aug 20 2026, 11:05 AM
best kept secret,,
https://www.amazon.com/dp/B0BB8R2973?lv=shu...rect=mhFallback
Steve
post Aug 20 2026, 11:35 AM
I use a stubby 13mm wrench. I did see S wrenches on Amazon. Never seen a Z wrench
post Aug 20 2026, 11:45 AM
914-6 GT in waiting
Often called a distributor wrench
sixnotfour
post Aug 20 2026, 12:14 PM
The support strap needs the hole slotted so it can move away , If you insist on a 13mm hex.. and your studs short..
Superhawk996
post Aug 20 2026, 01:16 PM
QUOTE(sixnotfour @ Aug 20 2026, 02:14 PM) *
(IMG:style_emoticons/default/agree.gif) Thats going to fail.
Crows foot is another option for tools
porschetub
post Aug 20 2026, 04:40 PM
QUOTE(Superhawk996 @ Aug 21 2026, 07:16 AM) *
Sadly yes (IMG:style_emoticons/default/agree.gif) ,not enough thread to support the hex nuts or the barrel nuts if all studs are the same ,well prior to fitting my exhaust I removed one bad one and ordered 12 new studs from Pelican , length was spot on .
The only fix I can see is to restud the heads ..don't think there is any other solution .
fixer34
post Aug 20 2026, 05:38 PM
Want to say I used a ratcheting box end, swivel head wrench.
I'll see if I can get a picture of it tomorrow.
post Aug 20 2026, 06:23 PM
914-6 GT in waiting
Yea, unless that’s some sort of optical illusion, you’re going to have to fix that.
nivekdodge
post Aug 20 2026, 06:52 PM
QUOTE(sixnotfour @ Aug 20 2026, 01:05 PM) *
even on a four
kevin
DennisV
post Aug 21 2026, 07:33 AM
QUOTE(sixnotfour @ Aug 20 2026, 10:05 AM) *
(IMG:style_emoticons/default/ohmy.gif) That is an interesting idea. Wasn't aware of these. Only the copper exhaust nuts which I think are 12 mm ATF and I was planning to transition to.
QUOTE(sixnotfour @ Aug 20 2026, 11:14 AM) *
Thanks for pointing that out. I believe that's an optical illusion because I haven't tightened the nuts before taking that photo. At least I hope that's the case.
I've learned a painful lesson during this project. Never trust the stud height on anything. I would have liked to think that a highly rated machine shop would have caught / corrected these things, since they would have had to remove and reinstall in many cases, but clearly not. It has bitten me a couple time now. Too short on the intake side and I had to replace them all. One of the barrel nuts on the exhaust side was too long and I could only torque it to 10 ft. lbs. before the wrench hit the stud.
DennisV
post Aug 21 2026, 07:42 AM
QUOTE(mepstein @ Aug 20 2026, 10:45 AM) *
Thank you for the photo Mark. That helps clarify.
I started looking for an SSI wrench based on @rudedude comment. That is a crazy looking wrench!
post Aug 21 2026, 10:35 AM
914-6 GT in waiting
QUOTE(DennisV @ Aug 21 2026, 09:42 AM) *
Yes, we also called them an Ssi wrench but distributor wrench will be an easier search. Definitely worth grabbing one for the tool box. They are pretty inexpensive.
bdstone914
post Aug 22 2026, 09:50 PM
bdstone914
@DennisV
[/quote]
Are all the studs the same lenght? The one puctured is too short.
Why is the piece of metal under the nut?
DennisV
post Aug 23 2026, 08:07 AM
QUOTE(bdstone914 @ Aug 22 2026, 08:50 PM) *
I can't tell you its purpose. Only that it is a new heat exchanger and there is a little bracket there.
post Aug 23 2026, 08:47 AM
914-6 GT in waiting
QUOTE(DennisV @ Aug 23 2026, 10:07 AM) *
It’s stock oem
Steve
post Aug 23 2026, 12:22 PM
QUOTE(mepstein @ Aug 23 2026, 07:47 AM) *
It’s stock oem
It helps prevent the exchanger from rattling.
sixnotfour
post Aug 23 2026, 02:43 PM
Dansks version of the bracket... is the odity.
Rusty OG in Pictures...
Nuts...
13mm Hex. notice ample room around hex for a flex socket 1/4 drive.
12mm Hex. More room..
10mm Hex flange,, non locking.. easy. Bug guys used to pay $3 a piece for these..
Countdown .. 13 12 10mm.. notice the same diameter contact area.. 10 & 13 slightly more than a plain 12 nut..
6 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
1 Members: markhoward
- Lo-Fi Version Time is now: 13th November 2026 - 12:20 PM
