> Battery Isolator: Any benefit?, What's the nominal "off" current?
LikesSummer
post Aug 20 2026, 01:23 PM
So assuming one has an unmodified car, what's the key-out, "off" current on these? I've got a 72 4 which doesn't even have a radio. I could certainly go through the wiring diagrams and determine this for myself if this is potentially anything other than zero, but there's a good chance I'll miss something quirky, so I'm asking the experts.
If turning the car off brings the background current to zero, then there's no need for an isolator obviously.
Replies(1 - 3)
flipb
post Aug 20 2026, 02:28 PM
Cars with appearance group have a clock. Most of them quit working decades ago but the ones that work would have some draw. I also noticed that my (presumably dealer-installed) radio isn't switched by the car's ignition so I have to make sure it's turned off.
Ninja
post Aug 20 2026, 02:46 PM
Without a radio (with a memory circuit-modern) or a clock it should be zero.
Easy way to determine.
Pull negative cable off of battery, attach a test light or DVOM (amps) between the cable and terminal and you'll have your answer.
930cabman
post Aug 20 2026, 03:17 PM
my 1975 example with the appearance group always has a small spark when I connect/disconnect the battery. I have never measured, but also never had an issue with a dead battery.
- Lo-Fi Version Time is now: 20th August 2026 - 07:22 PM
