> Today's question, Fuel Pump Terminals
kkid
post Aug 22 2026, 07:55 PM
Hello guys!
I am in the process of changing my 3 ports fuel pump to 2 ports. My 2nd (since my ownership) 3 ports pump is intermittently giving up. I have checked connections, relay and ground wires but it still likes to cut off sometimes. I think it is a fuel pump because it always happens at steady speed. So I am changing it to a new 2 port pump at the firewall near the original location.
I unplugged the white(already discolored as everyone knows) connector and am looking at the electrical terminals. There are 2 and sizes are slightly different. I think the one that is connected to a brown wire should be negative and the other one should be +. But the 2 wires at the connector are almost the same color because of their age.
Which one is the negative, bigger terminal or smaller terminal?
I can test with a multi meter but that can be useful only if I have a helper here.
Thanks in advance for the inputs,
kkid (IMG:style_emoticons/default/smile.gif)
Replies(1 - 4)
dtmehall
post Aug 22 2026, 08:24 PM
where is the fuel pump?
Original or in front?
Did you check the fuse in the relay plate?
Picture?
dtmehall
post Aug 22 2026, 08:26 PM
Picture would be help full (IMG:style_emoticons/default/yellowsleep[1].gif)
kkid
post Aug 22 2026, 09:00 PM
QUOTE(dtmehall @ Aug 22 2026, 07:26 PM) *
Hi,
Thanks for the reply.
It's a 74 and the pump is still located in its original position. I will install the new pump near the original location but it will be shifted from the hell hell area. The 2 port pump is too big to be on the corner.
I have checked the fuse and cleaned the contact at the relay board. But the problem still persists.
I will take some photos tomorrow.
kkid
post Aug 22 2026, 10:50 PM
Found my answer here.
http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php
Thanks SirAndy for taking that pic of the connector!
- Lo-Fi Version Time is now: 23rd August 2026 - 01:07 AM
