> Torsion bars
bajafreaks
post Aug 23 2026, 04:54 PM
I know torsion bars are extremely important piece to the front end puzzle.
Are these too far gone? Two pics are exactly as removed, the other two are brushed up with a wire wheel. The ware is only on one end of each one, and there is a slight "ridge" i can feel. ThanksAttached ImageAttached Image[attachment
id=982572]Attached Image Attached Image
Replies(1 - 4)
post Aug 23 2026, 04:57 PM
914-6 GT in waiting
Although I’m sure people drive around with similar or worse, I would not reuse them. If one does go bad at the wrong time, it could really spoil your day.
Basic rule of thumb is if there’s any wear, corrosion or grooving, they should be replaced.
jim_hoyland
post Aug 23 2026, 05:26 PM
Get that VIN ?
When a torsion bar needs replacement, does the steering feel change ?
post Aug 23 2026, 06:10 PM
914-6 GT in waiting
QUOTE(jim_hoyland @ Aug 23 2026, 07:26 PM) *
No. An old torsion bar may let the car settle a bit (it’s just a spring) but nothing really changes in feel unless they break, which can happen while moving or standing still, since they are always under tension.
bkrantz
post Aug 23 2026, 07:47 PM
Remember, in torsion bars (and other springs) the highest stress levels are just below the outer surface. Damage there is more critical.
- Lo-Fi Version Time is now: 24th August 2026 - 01:49 AM
