| NARP74 |
Sep 2 2026, 06:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,560 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
What's the trick to remove the shift finger assembly from the trans? PO had some sealant on it. Not sure if that is holding it in, or do I need to do something else to remove it?
| Shivers |
Sep 2 2026, 06:58 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,571 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
What's the trick to remove the shift finger assembly from the trans? PO had some sealant on it. Not sure if that is holding it in, or do I need to do something else to remove it? It maybe in gear. When in neutral it is all lined up and should pull out but if the fingers are turned and the rods inside are not lined up, the "shift fingers" can get caught up. I had all FUBAR but got it. Even a small amount can catch. |
| NARP74 |
Sep 2 2026, 07:01 PM
OK, I'll finesse it! I think I left it in first before I started taking things apart.
| NARP74 |
Sep 2 2026, 07:55 PM
Alright, that wasn't so bad. But it has a gasket on it that I did not account for. And they had some sealant on top of that. I thought the O-ring would be all that was there. I don't see a gasket in the PET I am looking at.
Now to find a gasket quickly. I was hoping to be done tomorrow. |
| NARP74 |
Sep 2 2026, 08:09 PM
Search shows this part number 901 303 191 01. Seems to indicate one or the other not both. Is this a change item? Do I need both the O-ring and gasket?
Lo-Fi Version | Time is now: 3rd September 2026 - 12:40 AM |
