| burlybryan |
Sep 16 2026, 06:49 PM
Member ![]() ![]() Group: Members Posts: 168 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
I'm prepping to install a fuel injected 2.0 into my car to replace the carbed 1.8. On the 1.8, my fuel pump was located at the firewall near the battery. I didn't label these wires and wondered if anyone could confirm that they are for the (former) fuel pump. They come out of the harness that winds around the firewall. I replaced the engine tray on this side, so they're currently not routed down if they are for the stock fuel pump location. Also, there's a random green with black thin wire with no fitting (ignore the yellow haze from some overspray). Any ideas on this one? I'm moving the fuel pump up front.
Thanks! Bryan Attached image(s)
| Shivers |
Sep 16 2026, 07:05 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,587 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I'm prepping to install a fuel injected 2.0 into my car to replace the carbed 1.8. On the 1.8, my fuel pump was located at the firewall near the battery. I didn't label these wires and wondered if anyone could confirm that they are for the (former) fuel pump. They come out of the harness that winds around the firewall. I replaced the engine tray on this side, so they're currently not routed down if they are for the stock fuel pump location. Also, there's a random green with black thin wire with no fitting (ignore the yellow haze from some overspray). Any ideas on this one? I'm moving the fuel pump up front. Thanks! Bryan I’m pretty sure the green with black goes to your oil pressure sender. Not sure what the rest of that is. |
| 914werke |
Sep 16 2026, 07:35 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,747 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
should be a round keyed connector, 2 wire, one of which is ground (Brn)
Lo-Fi Version | Time is now: 16th September 2026 - 10:39 PM |
