| nivekdodge |
Sep 24 2026, 07:12 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
One of the first things I remember when i started working on the first one was looking at the clutch pedal and saying to myself, " I'll probably learn why that rod is threaded like that." So clue me in
Kevin |
| Shivers |
Sep 24 2026, 08:00 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,608 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
One of the first things I remember when i started working on the first one was looking at the clutch pedal and saying to myself, " I'll probably learn why that rod is threaded like that." So clue me in Kevin This sounds reasonable: "Kinematic Engineering & "Over-Center" Action: The 914 pedal cluster utilizes a heavy assist spring. The clutch needs to be precisely dialed in so that the spring passes an "over-center" point during the first third of its travel. This reduces the physical foot effort required to hold the pedal down. A fixed cast pedal wouldn't allow the precision needed to align the pedal perfectly with this mechanical sweet spot." |
Lo-Fi Version | Time is now: 24th September 2026 - 08:36 PM |
