> 914 Rubber Bumper Tops, Back in Stock - New Molds?
frank_c
post Oct 2 2026, 10:41 PM
I received an email from 914 Rubber earlier in the week that the Front & Rear Bumper Top kit was back in stock (I requested an in-stock notification months ago). I went to the site this morning and discovered that they are out-of-stock again already (IMG:style_emoticons/default/sad.gif) .
I called 914 Rubber after checking the site just to confirm the stock status (yes, out-of-stock), and to also ask if these bumper tops were from the new mold that 914 Rubber was making. The sales agent said she was pretty sure these were from the new mold, but I forgot to ask when the stock will be replenished.
Question - did anyone here happen to purchase a pair of these this week, and if so, any feedback on the fit and finish? IIRC, there were some complaints about the pieces from the previous molds, which is why a new mold was created.
Thanks,
Frank
Replies(1 - 19)
bdstone914
post Oct 3 2026, 07:38 AM
bdstone914
@Matty900
JamesM
post Oct 3 2026, 09:02 AM
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
rick 918-S
post Oct 3 2026, 09:06 AM
Hey nice rack! -Celette
Steve
post Oct 3 2026, 10:26 AM
Also curious if they have been improved. Last set I bought from them stuck out on the ends really bad. I ended up using Autoatlanta instead. Fitment was way better.
saladin
post Oct 3 2026, 02:36 PM
QUOTE(Steve @ Oct 3 2026, 09:26 AM) *
D'oh, I pre-ordered and then received my 914Rubber bumper tops several years ago in February 2020 and they are still in the box. I should be ready to install the bumper tops within the year. Would these bumper top versions be ill fitting as well?
Ken
post Oct 3 2026, 04:10 PM
914-6 GT in waiting
QUOTE(saladin @ Oct 3 2026, 04:36 PM) *
Ken
Depends if they made new molds to correct the problem. The old ones definitely stuck out at the sides and didn’t look right.
doug_b_928
post Oct 3 2026, 04:29 PM
I’m in a similar situation, having ordered several years ago but just a few weeks ago having reached the point of being able to test fit them to the restored body. The rear bumper top fits well but, no matter what I try, the front bumper top sticks out on the right side.
Steve
post Oct 3 2026, 05:15 PM
If you do a search, there was some workarounds for the ends sticking out. Put washers under the studs on the ends and worse case drill holes in your bumper and use sheet metal screws to pull the ends in. Washers didn’t help my situation and I wasn’t going to drill holes in my bumper.
PCH
post Oct 12 2026, 11:11 AM
Just worked on installing a brand new 914Rubber bumper top on my early painted bumper. Unfortunatley the ends stick out on the sides.
Not sure if the early bumper has a different shape than a later bumper. I ended up cutting away some rubber. That helped but it was still sticking out. I then glued the rubber to ther bumper end clamped the fix. It will be next weekend when I see if it worked.
It'd sure be nice if things where just bolt and play.
rick 918-S
post Oct 16 2026, 06:55 AM
(IMG:style_emoticons/default/icon_bump.gif) "er"
rick 918-S
post Oct 18 2026, 09:47 AM
(IMG:style_emoticons/default/icon_bump.gif) er Tops? (IMG:style_emoticons/default/idea.gif)
rick 918-S
post Oct 18 2026, 10:27 AM
QUOTE(PCH @ Oct 12 2026, 12:11 PM) *
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Show us what the issue is.
Where is the cap sticking out?
Did you just purchase this top from current inventory?
Looks like 914Rubber stocks the front but no rear.
@Matty900
PCH
post Oct 19 2026, 01:27 PM
They were out of stock and 914Rubber sent me a notice that the front bumper tops were were back in stock, so I ordered one. I asume it was new stock.
Sadly, the Super 3m trim adhesive wasn't strong enough so the gluing failed. I'm contemplating black epoxy.
I will take pics next weekend. Cutting away some of the inside corner of the rubber helped to bring the sides in but they still stick out some.
Putting the car back together with new parts has been an exercise in extreme frustration-it's the exception when a part fits well enough so that it doesn't have to be modified.
I wish we had a handy guide to whose supplier's parts fit best for a specific application.
doug_b_928
post Oct 19 2026, 07:39 PM
Here are some pics from my test fit this summer. The bumper has never been bent. This is the left side showing perfect fitment. Notice that the line of the bumper top is straight with the edge of the bumper and it fits nicely on the top of the bumper.
This is the right side, not fitting well. It does not seat correctly on the top of the bumper, which causes the line not to be straight and for the edge to stick out past the side of the bumper.
I thought maybe the material of the bumper top was causing interference so I relieved some of the rubber material as shown below, but it didn't help.
I'm not sure if I'll drill a hole or two and use the screw method or attempt the glue method. I'm going to have the bumper chromed so I'm leaning toward the screw method so I know it will fit properly before taking the bumper for chroming. But I'd rather not be drilling holes in the bumper.
dtmehall
post Oct 19 2026, 08:33 PM
just eyballing your two photos, it looks like on your problem side the metal portion is hanging out a bit from you other side
was there body damage on that side?
dtmehall
post Oct 19 2026, 08:34 PM
sorry double post
post Oct 19 2026, 08:43 PM
914-6 GT in waiting
Since 914 rubber hasn't said the problem is fixed with a new mold, chances are it's the same mold with the same issues. (IMG:style_emoticons/default/sad.gif)
doug_b_928
post Oct 19 2026, 09:14 PM
No body or bumper damage. I purchased this bumper top in, I think,
about 2020 but didn’t test fit it until this summer (was too busy doing rust repair on the chassis to test fit parts).
Matty900
post Oct 30 2026, 12:50 PM
Hey, guys, I have an update. The issue with the bumper tops that I think was the conversation about a new tool that was floating around had to do with a production run that had an issue and how they were released from the tool. We had been out of these for a while, and when we had a production run, they were immediately sold out, with everyone who had them on their wish list. We just produced 50 sets of the internal metal for them and will start producing them, and should have some stock back in for Black Friday.
The issue with the over-tightening and pushing the side out I have a video on that I believe addresses the issue; I just need to find it, and I will post it here. I do want to know if this works for you or if you are seeing something else that I am missing.
- Lo-Fi Version Time is now: 24th November 2026 - 02:11 AM
