> Voltage regulator, Not regulating?
Flyinlow
post Oct 6 2026, 11:05 AM
Flyinlow
Hi.. installed a new voltage regulator a BWD (BORG WARNER) R588 on first start up generator light came on and stayed till I gave it a rev stock vdo volt gage climbed to 16 volts and looked like it wanted more. Is this a problem? What does the brain trust suggest? (IMG:style_emoticons/default/confused24.gif) TIA Dennis
Replies(1 - 9)
GregAmy
post Oct 6 2026, 12:11 PM
Troubleshooting, go to post #15:
http://www.914world.com/bbs2/index.php?sho...26479&st=20
JamesM
post Oct 6 2026, 01:46 PM
I would put an actual multi-meter on it rather than trusting the dash gauge, but yeah, 16v to the battery is something your battery is not going to enjoy for extended periods of time.
Flyinlow
post Oct 6 2026, 02:06 PM
Flyinlow
QUOTE(GregAmy @ Oct 6 2026, 11:11 AM) *
I don’t have a battery issue mine is a AGM only a few months old all I did was replace the aging VR.is there a test? As this has been installed the flaps won’t want it back
GregAmy
post Oct 6 2026, 02:39 PM
QUOTE(Flyinlow @ Oct 6 2026, 03:06 PM) *
I don’t have a battery issue...
That link is info to troubleshoot your charging system.
EDIT: link corrected to the following: http://www.914world.com/bbs2/index.php?sho...26479&st=20
And if you determine that this FLAPS VR is bad, they should warranty it.
Artfrombama
post Nov 9 2026, 03:24 PM
Artfrombama
Bosch 0 192 062 007 solid state regulators are now available priced reasonably https://cars245.com/en/item/bosch-F026T0223...ator-regulator/
porschetub
post Nov 9 2026, 05:15 PM
QUOTE(Artfrombama @ Nov 10 2026, 10:24 AM) *
Nice original looking upgrade unit ,could be solution if it fits the relay board and the cover fits nicely also ,cheers.
Flyinlow
post Nov 10 2026, 02:36 PM
Flyinlow
QUOTE(Artfrombama @ Nov 9 2026, 02:24 PM) *
Anyone have experience with this Bosch voltage regulator? F026T02230 Does it fit? (IMG:style_emoticons/default/dry.gif)
914Sixer
post Nov 10 2026, 03:25 PM
Yes Bosch unit is plug and play. 1/2 size and solid state.
emerygt350
post Nov 10 2026, 07:37 PM
QUOTE(Flyinlow @ Nov 10 2026, 03:36 PM) *
I have one. Didn't like it as much as the 30 dollar Amazon solid state adjustable I have been using for years now. The adjustable bit is really as good as it sounds.
https://www.amazon.com/dp/B014GN1YLK?ref=fed_share
- Lo-Fi Version Time is now: 23rd November 2026 - 10:16 AM
