> 914-6 remote oil filter
Montreal914
post Oct 24 2026, 10:00 AM
There currently is a discussion in the classifieds about 914-6 oil tanks that drifted into other discussions such as filter location.
Link: http://www.914world.com/bbs2/index.php?showtopic=379458
What would be the cleanest way to move the oil filter from the stock 914-6 location to a vertical installation on the lower firewall?
Can the filter console at the tank be capped with some U-turn?
Zero experience with a 914-6 setup, but it seems like replacing the horizontally placed oil filter has a high potential of making a mess. (IMG:style_emoticons/default/confused24.gif) Or is there a simple trick?
Replies(1 - 4)
mlindner
post Oct 24 2026, 12:01 PM
Montreal914, on the 914-6 you drain oil tank, the horizontal oil filter also drains. When removing the filter I place a paper towel under it....barely a drop. Best, Mark
post Oct 24 2026, 12:02 PM
914-6 GT in waiting
A small catch pan solves the drips. Why change something that works so well - on every 911.
infraredcalvin
post Oct 24 2026, 12:06 PM
Distracted Member
This is fancy, you can trim one out of an empty plastic container, but it works, I end up using it for other uses too…
https://www.pelicanparts.com/More_Info/RENT...RwaAoA9EALw_wcB
Montreal914
post Oct 24 2026, 12:34 PM
Simple enough! (IMG:style_emoticons/default/sunglasses.gif)
Stock location it will be.
Thanks!! (IMG:style_emoticons/default/beerchug.gif)
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: saladin
- Lo-Fi Version Time is now: 24th October 2026 - 06:32 PM
