| Shivers |
Nov 2 2026, 03:20 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,703 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
PMO fuel pressure regulator. With the barbed nipples it is 8mm for all of them including the one for the stock size 9.5mm supply line. The AN6 fittings are 9.5. How did you get around this? This one has 8mm supply feeding two 8mm nipples to the carbs. Am I missing something, do they all need to be one size? I ve been all over town trying to find a 9.5 barbed fitting with no luck. I’d call PMO but I could only find a fax number. A little help would be great. Thanks
| friethmiller |
Nov 2 2026, 04:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,604 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
PMO fuel pressure regulator. With the barbed nipples it is 8mm for all of them including the one for the stock size 9.5mm supply line. The AN6 fittings are 9.5. How did you get around this? This one has 8mm supply feeding two 8mm nipples to the carbs. Am I missing something, do they all need to be one size? I ve been all over town trying to find a 9.5 barbed fitting with no luck. I’d call PMO but I could only find a fax number. A little help would be great. Thanks From what I understand, 5/16" = 8mm and 3/8" = 9.5mm UPDATE: Amazon has the correct unions for a better reduction. Perhaps the inlet can be had as well. What's the threaded size of the inlet barb fitting? |
| friethmiller |
Nov 2 2026, 04:43 PM
BTW, I figured out what PMO stands for .... Leaky Gas Box! Make sure all those fittings are tight.
| Shivers |
Nov 2 2026, 05:18 PM
PMO fuel pressure regulator. With the barbed nipples it is 8mm for all of them including the one for the stock size 9.5mm supply line. The AN6 fittings are 9.5. How did you get around this? This one has 8mm supply feeding two 8mm nipples to the carbs. Am I missing something, do they all need to be one size? I ve been all over town trying to find a 9.5 barbed fitting with no luck. I’d call PMO but I could only find a fax number. A little help would be great. Thanks From what I understand, 5/16" = 8mm and 3/8" = 9.5mm UPDATE: Amazon has the correct unions for a better reduction. Perhaps the inlet can be had as well. What's the threaded size of the inlet barb fitting? I was actually hoping someone here would know It's not pipe thread, I think it is metric but otherwise I'm clueless. Thanks for the leak tip. I have some good pipe dope for the threads |
| infraredcalvin |
Nov 2 2026, 10:14 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,781 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
They make that part with AN fittings… I’d bet you can remove the barb fitting and fit a proper AN sized to your liking…
Lo-Fi Version | Time is now: 2nd November 2026 - 11:03 PM |
