| 914Sixer |
Nov 10 2026, 01:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,608 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I sold two nos 17mm ATE master cylinder. Buyers mechanic says seals failed. Need bench test to confirm that. Have overhaul kit to get seals from for replacement. Called PMB but guy on phone not able to say IF they could test them.
Attached thumbnail(s) |
| JamesM |
Nov 10 2026, 06:17 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I sold two nos 17mm ATE master cylinder. Buyers mechanic says seals failed. Need bench test to confirm that. Have overhaul kit to get seals from for replacement. Called PMB but guy on phone not able to say IF they could test them. Do you recall specifically who you talked to? Generally not something they test as its not recommend to rebuild them anyways. Most people know when they are bad so its not a common ask. May be able to rig something up but its probably easiest to just throw them on a car. Did they specify in what way they failed? Leaking externally? Not building pressure? |
Lo-Fi Version | Time is now: 10th November 2026 - 08:29 PM |
