> Mechanically Freshening a '74 1.8
andrewvolsen
post Nov 15 2026, 10:26 PM
I recently purchased this ‘74 and a large pile of spare parts. It was partially restored and is badged as a 2.0, has front and rear sway bars, etc. The engine is an EC case with non-2.0 heads and Weber carbs. I was told it was rebuilt to a 2056, but the guy who was working on it isn’t able to answer any questions about it (sad story), so I don’t really know what it is now or what the car started as.
It had been sitting for at least a year when I picked it up. I got it running last weekend and drove it around the neighborhood. It pulled pretty hard - felt like more power than I remember in my past 1.8s. While working on the carbs I noticed that the engine had no cooling flaps under the tin and it was leaking alot of oil from the bellhousing.
This weekend I pulled the drivetrain out of the car and stripped it down to a long block. Here’s what I noted during the disassembly:
  • cracked tabs on exhaust
  • of gear oil in the bellhousing, appears to be from trans input shaft seal
  • clutch disc contaminated with gear oil
  • shift rod welds cracked
  • flywheel teeth damaged
  • no air flow flaps or thermostat
  • intake manifold phenolic spacer cracked through at cylinder 2
Any suggestions on what caused the mangled flywheel ring gear teeth? The teeth on the starter pinion gear look pretty normal. Should I replace the flywheel?
I was previously posting about this car here, but the project scope has grown beyond the title of that thread: http://www.914world.com/bbs2/index.php?sho...379606&st=0
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Replies(1 - 1)
JamesM
post Nov 16 2026, 12:13 AM
Lots of interesting stuff here.
Mangled teeth on the flywheel could be a number of things. Kickback due to improper timing at some point, hitting the starter with the engine running, crappy starter, stuck solenoid, crappy flywheel, hard to say. From the looks of it it appears the teeth may be eaten all around the flywheel? If so I would suspect less that the issue was due to kickback. Given there are a lot of questions here I would say play it safe and replace it.
Where is that oil from on your engine main seal there?
You may be able to repair the heat exchanger flanges but that can be a crapshoot, the metal on the stainless ones is fairly thin and may have torn when it was over torqued but from here the break appears to be at the welds.
Shift rod was most likely damaged when someone pulled the motor at some point, so guessing it may have irregular bends elsewhere as well. Probably have a better overall experience if you just replace it.
Hopefully the engine wasnt run very long without the cooling flaps like that, thats a good way to cook things.
Did the seller say he built the motor himself or did he just install it? I see some familiar signs on the motor but then others that I know a particular builder wouldn't normally do.
I suspect it has a cam and/or larger valves due to the dual springs, the heads have been gone through for sure and the case has been apart but given the quality of the install there is no saying what state the motor is in overall.
IF it is a 2056 than 51cc 1.8 heads are going to give you a healthy compression ratio at which point would also lead me to suspect a large duration cam. Aluminum pushrods, and no swivel feet adjusters or solid spacers though. 44s are a big carb to throw on a 1.8 All together its a little strange.
Can you tell at what RPM it starts to come on cam?
You already have the engine out and the tin off. If it were me, given the missing cooling flaps and unknown displacement, I would pop the 3-4 head off and get a better idea of what you are working with.
any idea what the oil pressures were looking like?
8 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
1 Members: JamesM
- Lo-Fi Version Time is now: 16th November 2026 - 12:48 AM
