> Rev Too High, Idle jet?
Boothy
post Nov 22 2026, 08:28 AM
Cheers All,
Corrected my rich problem last spring where I re-jetted and it was too rich so it smoked a lot. It's cleaned out now but it still revs high when driving. Sitting it will idle comfortably at 1000. And when I lay on the the throttle is goes nicely. But when I let off it's reving high.
I'm thinking I need to drop the idle jet but advice will be appreciated.
1700 punched out to 2000. Weber 40s. 123 Ignition. Heavy springs on the linkage.
Thanks in advance!
Replies(1 - 1)
emerygt350
post Nov 22 2026, 10:59 AM
Is the 123 Bluetooth? If it is how abrupt is the curve in the 123? Checked for vacuum leaks? Not much of a carb person but vacuum leaks are always possible...
- Lo-Fi Version Time is now: 22nd November 2026 - 12:05 PM
