> Weird alternator fault, alternator inop for short time after start in cold weather
timofly
post Nov 24 2026, 11:28 AM
In ambient temperatures below 80F, alternator light and in-console voltmeter show discharge after startup. That continues for varying amounts of time, from 2-3 minutes in warrmer temps, longer when it's colder. Applying lots of throttle can sometimes extinguish light and voltmeter shows a charge. The engine idles normally until the alternator appears to wake up (light goes out, VM shows a charge) when it drops 200 rpm or more, so it apparently is loading. Once the light and VM indicate a charge, it's good to go for as long as I drive it, even with a few stops during the drive.
In sum, the alternator seems to be temperature and RPM sensitive. Belt is tight, connections have been checked for normal resistance, and the condition goes away once the car is well warmed up. Recent driving shows a worsening of the problem, so I need to see what the Brain Trust here thinks.
Replies(1 - 5)
worn
post Nov 24 2026, 06:51 PM
QUOTE(timofly @ Nov 24 2026, 09:28 AM) *
This is a great puzzle. What would run time after start do to the charging system? First thought is physical expansion is affecting a contact. I had an alternator pulley fail once on the way to Ockteenerfest. The pulley is made from two sheet metal halves spot welded together and the welds failed. My destination saved the day, as several people offered me spares.
emerygt350
post Nov 24 2026, 07:26 PM
Are you still using an old school voltage regulator?
Superhawk996
post Nov 24 2026, 07:51 PM
Brushes likely getting worn near wear limit with less spring pressure to keep them in contact with the armature or getting sticky in their brush holders inside the alternator.
Emery’s question above is valid too if using the points based mechanical voltage regulator - could be sticking there too.
anderssj
post Nov 24 2026, 09:39 PM
Dog is my copilot...
QUOTE(Superhawk996 @ Nov 24 2026, 09:51 PM) *
I had the same problem a year ago. I had the alternator rebuilt locally; both brushes were worn, one was well below wear limit...
porschetub
post Nov 24 2026, 10:01 PM
QUOTE(timofly @ Nov 25 2026, 06:28 AM) *
Have you tested the battery for "static " voltage ? should be 12.5v minimum, when the charge light is off and engine running what is the input voltage @ the battery ? ,how old is the battery also.
Temp has nothing to do with your issue ,without your replies I can only presume you have a failing alternator ,cheers .
- Lo-Fi Version Time is now: 24th November 2026 - 10:43 PM
