rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
big surprise. the end of the cam, under the oil pump, has the letters "C" and "H" stamped in it. that's all i have. any ideas?
k |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Ok, how 'bout the backside of the cam...does it have anything on it? (when you get it out)
rhodyguy |
as i said in the other thread i can only look at the thing for short durations. the valve adjs are just hammered. the damn thing is down to a case, cam, lifters, barrels, rods, and a crank. if i wanted to build a god damn engine i would have just used the 2.0 core that i already had. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
k |
rhodyguy |
i think this part is shot anyways. here's some #s tho. i would still like to know what it is. i'll post some pictures later.
running down the length of the cam on both sides. J1 19 C1 D1 CWC EP93 any ideas? k |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
maybe these guys made your cam.... (IMG:http://www.homegrocer.com/images/products/sugar%20cubes%20c%20and%20h.gif) |
SLITS |
The power of Google..................
Sounds like a european motorworks "G" grind.... If it has ever been used, and you do not have the lifters that were run with it- do NOT use it... If it is new, take your gambles on some lifters that are currently on the market and see what happens.. _________________ Jake Raby Raby's Aircooled Technology http://www.shoptalkforums.com/viewtopic.ph...e9a51f83769006f |
rhodyguy |
VERY noticable wear on one of the lobes. both visually and you can feel it when you run your finger over it. with the eccessive spring rates (duals) and whatever else was wrong, the lash caps and the adjusters were pounded pretty hard. so... new cam and lifters i guess. then there's the dilema of the "lifter issue" that i never saw or heard of being resolved. i don't know what the hell to do now.
k |
SLITS |
I posted the link for ya......looks like new cam / lifters.......call Jake or email him
rhodyguy |
a bunch of lobe pictures. overview. notice the wear marks on all of them.
Attached image(s) ![]() |
rhodyguy |
asdf
rhodyguy |
qwer
rhodyguy |
zxcv
rhodyguy |
hjkl
rhodyguy |
this is the worst of them all. you can make out the taper to the one side of the lobe. you can really feel the drop when you run your finger over it. why would it be so off center? lifter not sitting square to its bore?
k Attached image(s) ![]() |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
nice well worn cam.
Jake has new lifters and cams that work now, Kevin. |
rhodyguy |
so much for an engine with 3 tanks of fuel run through it. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) i spoke with him last week geoff. i'm hoping he will look at this thread. now to figure out which cam? rummor has it there's a std/std crank local. gotta see if i can get the easy payment plan on it. jeanne noted the spike in the visa bill last night. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
k |
Bleyseng |
If its gonna be a FI motor then its a 9550 from Jake
rhodyguy |
no. 40IDF. heat exchangers. for the silver car.
k |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Then get a gooder one. I like my 86b .500 lift 300 duration. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) this is a fast bus motor. well at least the pistons are BUS (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) 2.0L heads ported by me. running 40 IDF 32mm vents the tallest intakes I can get under the rain tray. |
SLITS |
As far as the failure.............
1.) Improper break-in of the cam 2.) Defective lifters (are they mushroomed) 3.) Improper matching of components (hard face cam lobes and soft lifters or visa versa...poor heat treating.... 4.) Poor oil supply 5.) A 9000 RPM run up (several missed shifts or the motor was pounded & starved for oil) 6.) Excessive valve spring pressure 7.) Coil bind of the valve springs (improper installed height - Bent pushrods?) 8.) Defective grind on the cam I can keep guessing..................... |
Lo-Fi Version | Time is now: 11th July 2025 - 03:33 AM |
