Dry Sump Set-up, Tell me everything I need to know... |
Britain Smith |
Sep 23 2005, 10:55 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I have this thought of converting my turbo type-4 motor to dry sump due to ground clearence with the deep sump and the return line for the turbo, etc. Can someone give me a run down of everything I need to know to convert a type-4 motor to dry sump? What parts are required, how much do they cost, where does all the plumbing go, etc. I know that many feel that these motors don't benefit from a dry sump system, but that is beyond the point in this application.
-Britain |
Britain Smith |
Sep 23 2005, 03:15 PM
Anybody? Anything?
Brian Mifsud |
Sep 23 2005, 03:18 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
here's a great source of proven parts.. at pretty well the best pricing..
Sumps and Pumps... http://www.colemanracing.com/ |
machina |
Sep 23 2005, 03:20 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
The racers at the runoffs know the most about this setup.
Jake was working on a kit for this. I think it involves a 2 stage oil pump, oil tank, lines, etc. Think racer chris has a pretty elaborate dry sump system with multiple scavenge pumps. Regarding the deep sumps, almost every 912,356,914 I have seen has one hanging down. Looks scary but not as big a deal as you might think. |
Mueller |
Sep 23 2005, 03:28 PM
the new Z06 uses a dry sump oil system, might be the 1st street Chevy to do so (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I cannot think of any negatives except the price (pumps start at about 300 for a single stage and go up a $100 per stage it seems) and how to drive it...for your application, the belt drive would be much easier than on a standard /4 motor due to the fan housing.... all /6's except for the new 996 and Boxsters use dry sumps and if I am correct, the twin-turbos and GT3s use a dry sump system as well... |
machina |
Sep 23 2005, 03:37 PM
its probably an extra 40 or 50 pounds. the pumps I have seen on TIV's looked like extended units in the normal location. think the drag racers have done it the most with TIV |
Aaron Cox |
Sep 23 2005, 03:39 PM
John rogers used to have a dry sump type IV racer...
he would know (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
machina |
Sep 23 2005, 03:40 PM
Attached image(s) |
Aaron Cox |
Sep 23 2005, 03:43 PM
what are the various stages for?
2 stage - one scavenges and one pumps pressure into the case? right? 3 stage??? |
Mueller |
Britain Smith |
Sep 23 2005, 03:48 PM
Here is my problem...and the car will be lowever a good 3-4 inches farther.
-Britain Attached image(s) |
Britain Smith |
Sep 23 2005, 03:49 PM
It sure does look cool though...
Britain Smith |
Sep 23 2005, 03:50 PM
another...
Attached image(s) |
Aaron Cox |
Sep 23 2005, 03:51 PM
bolt in engine cradle?
maybe raise it up? or fab some tubes on the cradle to run under the deeeeep sump? |
Root_Werks |
Sep 23 2005, 04:00 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
A 912 is basically a 911, shoot, just go get a 911 oil tank ect... Easy.
Aaron Cox |
Sep 23 2005, 04:06 PM
tank is the easiest part. plumbing a front oil cooler??? |
ArtechnikA |
Sep 23 2005, 04:13 PM
one stage to scavenge the turbo oil... |
Britain Smith |
Yea, I have thought about the 911 tank. I also already have a front mounted fender oil cooler with Carrera fan.
How do you set-up a dry sump system? Where do you put the lines? -Britain Attached image(s) |
Andyrew |
Sep 23 2005, 05:45 PM
What are the advantages of a dry sump? like say for a sbc?
Aaron Cox |
Sep 23 2005, 05:53 PM
nascars are dry sumped.... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:22 PM |
