> Caliper Powdercoating experience/advice ?, rear caliper disassembly ?
ChrisFoley
post Aug 6 2003, 05:15 PM
I am Tangerine Racing
The owner of this car wants the calipers powdercoated to match the interior. (IMG:style_emoticons/default/smilie_pokal.gif)
After splitting the rear calipers I fully disassembled everything and cleaned them, except for the parking brake arm and shaft which I don't know how to remove. It seems that there is a rubber seal or something in there that won't survive the heat but I can't figure out how to get it apart. (IMG:style_emoticons/default/confused24.gif)
Anyone have experience with this?
The front M calipers have those thin machined pieces as well as the halves. I wonder if I should bolt them together with something thin in between the pieces. Any good ideas already in practice that someone knows about?
Replies(1 - 18)
Mueller
post Aug 6 2003, 05:46 PM
914 Freak!
Could you talk him into just using that caliper paint?
Eastwood (and others) sell about 10 or more different colors
Just a thought (IMG:style_emoticons/default/smile.gif)
ChrisFoley
post Aug 7 2003, 04:15 PM
I finished disassembling the rears today. There's a 25mm dia metal plug that has to be drilled out to get at the circlip holding the pivot shaft in its bore, and there is a rubber seal just under the actuating arm - as well as lots of grease in there.
Took everything to the powdercoating shop after lightly bolting the assemblies together. They are going to bake them, blast them, disassemble, mask and coat, then bake again. Price about $45 each.
It's gonna cost the owner almost $1000 by the time they are back on the car. Nice to have customers that don't even blink at the cost of these "little" jobs.
Mueller
post Aug 7 2003, 04:33 PM
914 Freak!
You are going to show us pictures once done?
correct??
Lawrence
post Aug 7 2003, 04:35 PM
$1000 dollars? (IMG:style_emoticons/default/ohmy.gif)
Does he get kissed first?
redshift
post Aug 7 2003, 04:46 PM
Bless the Hell out of you!
I'd also like to see pictures of the $1,000.00.
M
Mueller
post Aug 7 2003, 05:00 PM
914 Freak!
Chris,
Are they using a High Temp Powder Coating or regular powder coating?
( 1000° vs 400° )
ChrisFoley
post Aug 7 2003, 09:03 PM
Mike,
not high temp.
That $$ figure includes travel to and from the car's current location - two times, R & R, total disassembly and cleaning, new seals etc, delivery and pickup at Airborn Coatings, coating price, hone rear cylinders, custom machined steel plugs, reassembly and bleed brakes after installation.
I'll try to remember to take pictures after coating.
Part Pricer
post Aug 8 2003, 05:32 AM
Believe everything I post
I'm really concerned here. (IMG:style_emoticons/default/sad.gif)
What color is the interior? (IMG:style_emoticons/default/blink.gif)
URY914
post Aug 8 2003, 05:35 AM
After all is done I hope you'll be able to see the darn things.
Too much money for too little effect.
Paul
ChrisFoley
post Aug 8 2003, 07:16 AM
QUOTE(Paul Heery @ Aug 8 2003, 07:32 AM)
RED leather seats and door panels, red carpet, black leather backpad and black vinyl dash & trim.
This is turning out to be a full concours restoration.
Calipers will be slightly visible behind black Fuchs alloys - 7,8 x 16
Mueller
post Aug 8 2003, 09:06 AM
914 Freak!
Sounds interesting.....I'm all for doing things a little "different" (IMG:style_emoticons/default/smile.gif)
ChrisFoley
post Sep 8 2003, 04:00 PM
Finally, I have the calipers back together after waiting a while for new seals. Have a look.
ChrisFoley
post Sep 8 2003, 04:01 PM
and
Rusty
post Sep 8 2003, 09:14 PM
Did you mask off the e-brake arm, or disassemble that part of the caliper, too? (I can't see if the bottom metal disk was removed.)
-Rusty (IMG:style_emoticons/default/smoke.gif)
post Sep 8 2003, 09:25 PM
Resident German
for a $1000 bucks you could have cleaned those nuts and bolts before you put them back on (IMG:style_emoticons/default/laugh.gif)
a wire-wheel sometimes does wonders ...
Andy
ChrisFoley
post Sep 9 2003, 05:18 AM
QUOTE(Lawrence @ Sep 8 2003, 11:14 PM)
here's a pic of the rears during reassembly.
ChrisFoley
post Sep 9 2003, 05:21 AM
QUOTE(SirAndy @ Sep 8 2003, 11:25 PM)
Andy
Hey Brad2,
they weren't too bad, imo. The black anodize was still largely intact and I didn't want to remove it. I only wirebrushed the threaded mating portions, lol.
Rusty
post Sep 9 2003, 05:31 AM
Very, very nice. You do good work, Chris.
- Lo-Fi Version Time is now: 9th June 2026 - 02:19 AM
