Joseph Mills |
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 ![]() |
Tank condition:
Smooth rust on walls with mottled or layered rust on bottom. However, there are no visible particles, flakes, etc. I stirred and scraped with my hand and can feel some grittiness from the walls. The fuel clouded up, but still no visible particles, not even sand grain size, only microscopic sized that clouds up. The small "sock" screen feels "clean". Since treating a tank is an expensive proposition, what is the determining level of rust acceptance? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I don't want to spend 150 bucks just to have pretty fuel. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
just think of sand blasting your jets or fuel injectors. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Get a micron filter until you can get it pulled and cleaned. |
Toast |
Not bad for carrying sway bars. ![]() ![]() ![]() ![]() Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region ![]() |
Too much is when your fuel filters get clogged with rust flakes.
LvSteveH |
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 ![]() |
Your tank sounds pretty funky. A peak inside Toast's tank revealed no rust at all and it was very clean, yet she had accumulated enough debris to clog her filter.
Personally, tanks are cheap, I'd get another one, have it cleaned out at a radiator shop, paint it all pretty, and then swap it out for the one you have. I'm not overly fond of the tank coatings, it's too easy to find a nice tank and do it right. |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
When I looked inside the tank on my '71, I expected to see some rust, since I'd been having problems with clogging idle jets. I was surprised at how little there was. The "sock" was orange, and the return had a ring of orange goop on it, but the tank walls themselves were 95% rust free. A few spots near the bottom, but nothing else. I cleaned the sock and flushed the lines, and fit two new fuel filters, and haven't had any more trouble.
jr91472 |
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 ![]() |
I coated mine 2 summers ago with the POR tank kit. Made the inside look like new.
so far so good. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) JR |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
PLEASE PLEASE take care of it while you have it open.....
My dad didnt when he "restored" it and i'm left to fix it.... |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
How hard is it to restore a tank, what tasks are involved? Isn't it just draining the tank, cleaning it, and then coating the inside with some tank-lining liquid and let it sit overnight? I'll have my tank out soon (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
My tank was a mess with rust. I used the POR15 tank kit:
POR15 Tank Kit Took about a week to totally do it but the inside of the tank was nice and clean. Used 1 fuel filter in 2 years. Spoke |
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
$50 bucks to get boiled/stripped, por 15 kit, por 15 outside
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I am NOT a fan of tank liners. Heard stories about improperly applied liners coming off and clogging tanks. And besides that, the tank is fine as long as it's not sitting. Sitting = Rust.
Joseph Mills |
Mark, If a sealer is not used, what keeps the bare metal of the tank from rusting again? If not using the sealer, can I simply have the tank "boiled" at a radiator shop and leave it at that? Has anyone else used this Por kit? .. |
bd1308 |
nothing keeps the tank from rusting except either POR15 OR keeping alot of gas in the tank.......
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
A quality radiator shop will boil it and coat the inside with an epoxy system...POR 15 is not the only thing out there.
I had mine done, 150 boiled and epoxy coated. In order to get it really clean, he did drill a 2 inch hole on the drivers side to get behind the middle baffle and ensure it was all cleaned out. Rich |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,733 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
If you cheap out on your fuel tank, you'll live to regret it. $150 too much to invest in a fuel tank? Fuel injectors are at least 2/3 of that each.
Gastank Renu, OK? If you go with the interior and exterior coatings, you'll get a lifetime guarantee, and thier coatings are baked on and will not come off. You can get a interior only coating which, I'm sure will last your lifetime, but you'll only get a two year guarantee. If you go this route, you can paint the exterior of your tank for a "correct" appearance, if that's important. I've heard horror stories of DIY fuel tank coatings that have sloughed off and made a real hardcore headache. |
Lo-Fi Version | Time is now: 17th June 2024 - 07:23 AM |
