Bump Steer Kit |
Bump Steer Kit |
michelko |
Oct 2 2005, 03:07 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi everybody.
Anyone knows the measurements of the bump steer kit? Washer size, screw length? (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
michelko |
Oct 3 2005, 01:16 PM
O.K. turned out one screw that hold the steering on the rack. it is a M10 20mm Screw. So if i want to use 10mm Shims under the Steering i have to use 30mm Screws.
But.... can i use 10mm shims? There is no much room above the steering, maybe 5-8mm i guess. Has nobody the measurements of that (weltmeister) bump steer kit? (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
Rough_Rider |
Oct 3 2005, 03:13 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
Good question, i didn't think to measure them before installation.
Can't be much grater than 10mm. I can't see any harm in installing 10mm spacers using the longer bolts & seeing how the tie rods settle after its all back together on the ground. Ideally you want the rods horizontal or pointing down towards the outside. But you already knew that (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
SirAndy |
Oct 3 2005, 03:17 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i'm not sure, but 10mm sounds too much. i can't get to my car right now (it's at the shop) to measure for you ... sorry, not much help here, (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Andy |
Aaron Cox |
Oct 3 2005, 03:19 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
id say ~7-10mm i could sworn the welt pieces were almost a full 10mm (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
motorhead |
Oct 3 2005, 09:13 PM
Member Group: Members Posts: 67 Joined: 11-September 05 From: tehachapi, ca Member No.: 4,784 |
I seem to recall reading/hearing somewhere that the "bump steer kits" were a bit too much unless your car is REALLY low.
porschecb |
Oct 3 2005, 09:38 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
I just bought a set from Pelican Parts & my car is really LOW!!!!!! I can spec. it for you but then I would have kill you! 2 & 1/4 & 2 Inch! sorry my son took my MM tape. spacers are 2 1/4 of an inch. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Aaron Cox |
Oct 3 2005, 09:40 PM
PICS? SRP Kit? |
porschecb |
Oct 3 2005, 10:27 PM
Pic's are on pelican parts. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Aaron Cox |
Oct 3 2005, 10:40 PM
you said spacers are 2.25" ... the welt kit is about 1cm thick..... |
michelko |
Oct 3 2005, 10:48 PM
do i have to pull the tank. There is an bearing that canĀ“t be reachend with tank in. Maybe the steering axle slips right through?? (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
michelko |
Oct 3 2005, 10:53 PM
this one
Attached image(s) |
Lo-Fi Version | Time is now: 16th June 2024 - 05:06 PM |
