Brotherbob |
Lazy Hack ![]() ![]() Group: Members Posts: 152 Joined: 6-September 05 From: Granbury TX Member No.: 4,756 ![]() |
Engine that was donated to the cause. EA033494
Cast into pan 004.101.102A ------------------------------------------ Parts engine that tin and fuel injection comes from. EA0171960 cast into pan 004.101.101A ------------------------------------------ Transaxle 914 11HA0035381 If you can decipher these codes please do , it would help when buying parts and such. All of this is going into a 72 914 under construction. (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
EA motors are 1.7 motors; standard for mid-71 (I think) through 73 (except California 73s, which were "EB").
The transaxle is more challenging... I think the switch to the style of number you list was made in mid-72. I think the number you list is a 72 tailshifter transmission, but I'm not completely certain... Could be later, and a sideshifter. It should be obvious, though--if the linkage goes into the side of the transmission, it's a side-shifter. If the linkage enters the transmission through the end cover, it's a tailshifter. All 914-4 transmissions had the same gearing. The only real difference was the shift linkage. So we don't usually worry that much about exactly what year of car the transmission came out of. --DD |
Lo-Fi Version | Time is now: 16th June 2024 - 05:16 PM |
