| Mueller |
Oct 5 2005, 11:12 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
All aluminum, good power and reliable....pretty cheap as well since about the only market for them is for replacements or sandrails.
A few sites with some good reading about them: C and G Performance and Funco sandrails I know Kennedy Engineering makes an adapter plate and flywheel for it as well and unlike most Honda 4 bangers, they turn the correct direction (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.cgperformance.com/images/CG%20honda%20engine%20WP.jpg) |
| dmenche914 |
Oct 5 2005, 11:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Mike: sounds like a great idea, You know I have a Buick V6, lots of power, but it is heavy, all cast iron. An aluminum V6 would be better.
One thing I would ask is vibration issues with a V6, the Buick is not that smooth at certain rpms. even Buick cars had this issue, but it can be worse when the motor mounting is changed (change in motor mount stiffness in certain directions) You might run into this, then again, I think some of them fancy japanese V6's have counter shafts to help smooth them out, If that is the case, you probably wont have the V6 vibration issues. as far as fit, I have now idea on it size. what knid of HP and torque do you expect from these engines? I still really like the idea of a subaru however (although the subaru engine is more pricey) just becuase it is a flat motor. i have heard rumors of folks intaling radiaotrs int eh engine bay, I thnk with teh low profile subaru. An engine bay radiator is nice, as it avoids lots of fabbing. any one have a photo of one of these set ups? |
| Tobra |
Oct 5 2005, 01:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
The S2000 engine spins the right way too. Vibration with the Honda 6 should be minimal, would you mount it transverse or longitudinal?
| airsix |
Oct 5 2005, 01:26 PM
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Whoah. You just stopped me dead in my tracks. The crank spins in the correct direction? I assumed that like the Honda/Accura 4s they spun the wrong way and I never gave them a second thought. You've really got my attention now! This is great to hear. I love options. -Ben M. |
| URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,067 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Isn't that the engine they use in the ATOM?
Paul |
| Mueller |
if mounted to a 914 transmission, it can only be mounted one way...longitudinal......... |
| airsix |
Oct 5 2005, 01:30 PM
You're making me salivate. The S2000 has a curb weight of 2835 pounds. Think about that engine in a 914 that weighs 30% less. I assumed that engine spun the wrong way and so I never considered it an option. Now you really got me thinking. -Ben M. |
| Mueller |
Oct 5 2005, 01:48 PM
for some reason the V6 motor seems more appealing to me....oh well, more dreaming since I've got this Type IV to build for my car (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
| Andyrew |
Oct 5 2005, 02:04 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
I'd do it.
If the S2k motor turns the correct way, I would take on that engine first.... And cruzing and top speed would be "interesting" Give a much sportyer feel vs a v6... but I'd honestly do eather... Only problem is they still sound like honda's... |
| Mueller |
Oct 5 2005, 02:06 PM
I don't know, I bet a V6 with some headers would sound pretty sweet and not have that typical Honduh sound (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| Andyrew |
Oct 5 2005, 02:13 PM
true...
It will still sound small... me thinks... ie less dispalacement... But Im sure there are header setups and such that could aleviate that... Im still working on a muffler system on my car that sounds bad ass and livable.... (ie tunable..) Not a simple task.. |
| MattR |
Oct 5 2005, 02:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Yeah, but the S2000 has a MUCH siffer chassis with new technology in suspension, brakes, etc. I dont like the styling, but if you're looking for performance, get the newer car and "downgrade" things like power steering, leather interior, ac, etc. |
| dmenche914 |
Oct 5 2005, 02:17 PM
still haven't seen any HP and torque numbers. what kind of power for the V6? what about the S2000 engine, what is it a V6 also? What kind of rpm limit does the S2000 have? 60 mph in first with 914 gearing would mean an incredible redline wouldn't it?
Please post some of the performance numbers for these engines you all are discussing, wiegths would also be interesting too. thanks |
| d914 |
Oct 5 2005, 02:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
s2000 vetech kicks in at 6k with a 9k redline 240hp
v6 header and airbox about 220-240hp |
| Andyrew |
v6 is 225 with 250 capable with headers and tuning.
s2k? um, 250? s2k has 9k redline. |
| Trekkor |
Oct 5 2005, 02:24 PM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Doesn't the S2k have a 9000k redline and make 245hp? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
I've heard it will actually rev much higher but the trans, alternator and other belt driven stuff starts coming apart. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Can a 901 box handle those rpm's? KT |
| Mueller |
Oct 5 2005, 02:26 PM
as copied from Funco:
No weight on the iron block V8, but it's gotta be up there in weight !!!! These are motors currently being installed in sandrails.
I'm guessing the newer 3.5 motors put out more power and torque S2000 is a 4 banger
| 914GT |
Oct 5 2005, 02:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Just got my wife a new Acura TL a couple weeks ago. Now that would be a nice engine for the 914 - 270 HP V6 and smooth as glass.
| Mueller |
Oct 5 2005, 02:30 PM
oh yea, huge price difference between the S2000-4 and the V6...
cheapest S2000 on eBay...starting at $3800, motor only tons of V6's...average price $600 to $900 for a low mileage unit |
| dmenche914 |
Oct 5 2005, 02:39 PM
Now them is some impressive figures, thanks. Yeah, old type I VW motors are not top of the line anymore in sand rails, my uncle has a Rover V8 Turbo Aluminum enigne in his rail. I think the rail weighs under 1000 lbs, that might even be with driver, I forget!
Subarus have the advantage of keeping the weight down low with the flat design, I believe the oil pan does hang lower than the 914 engine, but it can be modified to gain back some of the ground clearance. Again, the subaru sells for a bit, they are less common than Hondas, and they are snapped up by other engine swappers and kit car folks (nice swap in Vanagons) Mike, is the V6 in the photo altready yours? If so can you figure if you need to cut any of the body to fit it? On my Buick, the front engine shelf had to be notched to clear the water pump shaft. What about a engine bay radiator, that would really be nice, save cutting up the front trunk, Anyone seen this been done? |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:17 PM |
