Cold Start Idle, & I have read all the past postings |
Michael J |
Oct 16 2005, 11:31 PM
Welcome to 2007 Group: Members Posts: 268 Joined: 23-November 04 From: Olympia, WA Member No.: 3,166 |
Folks I am at a loss. My '72 1.7 with stock D-jet works almost perfect. But I can not get the engine to idle at higher RPM when I first start it.
So here is what I know. When cold the engine starts on the first revolution and idles at 900 to 1000 rpm. Same after warm up. I adjusted the Throttle Pos Switch today and exceleration at operating temp is much smoother and responsive (probably has nothing to do with the warm up idle). I pulled the AAR today and it works as it should. Checked (again) for vacum leaks and all seems OK. I did pull the oil bath air cleaner off and replaced it with a paper filter from a '73. So the engine no longer has an intake air pre-heater. So with that little bit of info does anyone have a suggestion? |
Dave_Darling |
Oct 16 2005, 11:34 PM
I suggest driving it and not worrying. I think that's more than "close enough for government work"...
--DD |
Rand |
Oct 16 2005, 11:38 PM
A lot of people wish their car acted just like yours. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Michael J |
Oct 16 2005, 11:46 PM
But it is so close and I am so anal about little things not working. Not complaining just doin some head and chin scratching. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
ArtechnikA |
Oct 17 2005, 05:43 AM
ignition timing can have a significant effect on idle speed; check that.
Lo-Fi Version | Time is now: 12th June 2024 - 01:14 AM |
