Weber Triple Throat: Which screw, to reveal the main jets? |
olav |
Oct 19 2005, 07:40 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Could someone post a photo. I have forgotten which screw to losen to get to the main jets. I have the Weber book but the picture doesn't show it explicitly enough to remind me. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
sixnotfour |
Oct 19 2005, 08:13 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Go here;
http://www.914world.com/bbs2/index.php?act=...=ST&f=2&t=40075 Go to the carb side picture .. the top flat blade brass screw is idle jets. straight down(bottom of float boal is the 10mm hex of the main jet holder . take these out main jet on the end. 3 on each side of carb. The other 10mm drains the float bowl. Carefull when tightening , sometimes the jet holder breaks off at the holes. Carefull when removing it drains the Gas out of the float bowl. |
olav |
Oct 19 2005, 08:19 PM
Lo-Fi Version | Time is now: 8th June 2024 - 12:06 AM |
