Need electrical advice, Adding auxillary fuse: box or block ? |
jim_hoyland |
Nov 5 2005, 07:43 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I want to install an auxillary fuse strip on the passenger side. Was looking at this web page
http://www.rallylights.com/hella/Relay_Box..._Fuse_Boxes.asp My question is which type would be most appropriate: Fuse Bloclk-HL62936 or Fuse Box-HL62935 ? And, is there another option that I shold consider ? |
MecGen |
Nov 5 2005, 08:53 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi
This is how I did it... Aux Box Later (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
jim_hoyland |
Nov 5 2005, 02:25 PM
You bring power stright from battery ?
MecGen |
Nov 6 2005, 05:50 AM
Hi Jim
Bad habbit of mine - post and run (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Yup, I ran a good guage power wire from the battery, maxi fuses (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) I used a small 3 fuse Maxi fuse holder, that I took off another car, and mounted it to the battery tray, this insures no fires.... also the relay board (inside) that I used has a sepparate fuse just for the relay. I did this because I had about 20 different car harnesses laying around, picking parts were easy, and I never seen a jobber fuse box up close, so I can't say if they are good or not. Good luck with it +Karma Later (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:28 AM |
