Ray Warren |
Member ![]() ![]() Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None ![]() ![]() |
Air intake temp sensor.
Attached image(s) ![]() |
Ray Warren |
Fast idle solenoid.
Ray Warren |
TPS
Ray Warren |
Injector resistors
Ray Warren |
Map sensor
Ray Warren |
Cold start injector block off plate.
Ray Warren |
Mixture meter
Ray Warren |
Rich / Lean adjustment knob
Ray Warren |
Programer
Ray Warren |
Backpad removed and carpeted
Ray Warren |
ECM , fuse block and relays
Ray Warren |
I have been driving the car with the SDS all summer
and couldn't be happier. I have not had the car on a dyno to be expertly tuned. I tuned it myself with the narrow band o2 sensor and the mixture metre and by sound and feel. It starts and runs perfect every time. I'm sure that if I got it tuned professionally it would be even better. It's a nice simple system. I would recommend it to anyone. |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Do you have any CHT or EGT data on your setup? Typically, these engines tend to run pretty hot when tuned to run at stoich.
Kerrys914 |
Dear, the parts I just sold paid for that part ;) ![]() ![]() ![]() Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) VERY nice. Looks very well thought out and installed...The mark of a pro (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
Ray Warren |
Unfortunately there is no extensive data logging with the SDS. SDS data logging I do have a cylinder temp gauge and it usually runs about 275 to 300. My oil temp gauge is a factory gauge and it usually runs around the "T". |
jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
Nice job, Ray. Looks like a super sharp car you've got there. I've got an SDS system lying around that I plan to put in along w/ a Suby 2.5L engine. I'm glad to hear that your experience was so straightforward and positive. I'll be sure and keep you in mind when I (eventually) get around to messing with it.
p.s. Any shots fo your Hall sensor/magnet install ? Probably impossible to see it now. |
Ray Warren |
It's a fuel only system (EM4D) I will eventually get a Jake Raby Mallory. I wanted to keep it simple. There is some pictures of Mark Henry's SDS install with ignition on the forum. Do a search on SDS and you will find it. |
lapuwali |
I assume you're running off a thermocouple under the spark plug for the CHT? If so, then you're in great shape, and it looks like the usual rule of thumb about running hot near stoich may not be true. |
Ray Warren |
Yes I do have the spark plug type sender but I do not know if I am running at stoich. I would suspect it would be close to stoich. Using the narow band o2 sensor and mixture metre is not accurate. I would like to get it tuned with a wide band metre. (maybe next year) |
Ray Warren |
CORRECTION
I just went out to the garage and looked at my temp gauge. It usually runs around 300 to 325. |
Lo-Fi Version | Time is now: 11th June 2024 - 01:08 AM |
