> front strut shock removal
dmenche914
post Nov 15 2005, 08:52 PM
Hi all: I got a pair of front struts equiped with adjustable shocks, the struts are not on the car. i would like to put the adjustable shocks in my car, and figure it would be easiest to swap the adjustable shock, rather than the whole strut assembly (save redoing wheel bearings, my rotos are half used, and I figure I can deal with the bearings later when the rotors need replacing)
Here the problem, we can't figure how to remove the adjustable shock from the spare struts (we haven't gotten to the ones on the car yet, but they will also be removed)
How is the shock removed from the strut assembly? There is a large hex nut on top of the shock, a bent over locking washer, a large notched washer under it, folled by a rubber washer then the top of the strut (with body attachment points)
We tried putting the strut in a vice, peened over the lock washer, and turning the large nut, but can't break it free.
How can the shocks be removed?
PS these are early style (ball joint bolted in) struts if that matters.
thanks
Replies(1 - 5)
Lou W
post Nov 15 2005, 08:54 PM
Region Association: Spain
Do you see a cotter pin at the bottom of the strut?
davep
post Nov 15 2005, 09:19 PM
914 Historian
Is it just spinning without loosening? You will probably need an air tool to spin it fast. The shaft will spin in the shock itself. If you can restrain the upper mount you should be able to get the nut free.
The real trick is getting the shock out of the tube. It cost me a big buck to get a tool made to do that. No one else in the area has one.
dmenche914
post Nov 15 2005, 09:29 PM
The top nut will not turn, seems to flex a bit like it is attached to rubber, but does not turn( we try any more and the vice holding the strut will probably tear off the work beanch!!!)
i do not see any cotter key on the assembly.
Surely someone must have replaced front shocks before, without replacing the entire strut right????
If we can't get the shocks swapped,t eh only other option would be to change out the entire strut assembly, but that would involve wheel bearings, and possibly loss of the inner bearing if we can't get it off the stub axle.
Anyway, any more advice on the removal of the shock from the strut?
Jeroen
post Nov 16 2005, 08:38 AM
Region Association: Europe
clamp the big notched washer in your vice
this prevents the shaft from turning when you loosen (or tighten) the top nut
the shock is secured in the strut where the shaft enters the strut
the top part of the strut (I think it's called a gland nut) can be turned off the strut, so you can take the shock out
you'll need a big monkeywrench to do this
Mike D.
post Nov 16 2005, 01:31 PM
OK, It runs now, and pretty good too!
Yes, Big Pipe Wrench, and Lefty Loosy... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Where in CA are you?
- Lo-Fi Version Time is now: 14th April 2026 - 06:10 AM
