736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
Somehow I have a program that took over all of the picture files. Everything on my computer is save as a 602photo suite file, or should I say tries to open in the 602 photo program. I would like my pictures to open up into a different program such as paint. How do I change my settings to make paint my default viewer.
I know it must be an easy fix. |
Howard |
Incontin(g)ent Member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None ![]() ![]() ![]() |
Right click on the file, select 'open with', pick the program you want to use and check 'always use this'.
Rockaria |
ZippidyDoDah... ![]() ![]() ![]() Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None ![]() |
In Windows you gan globally change the program that automatically opens a specific file type.
START --> CONTROL PANEL --> FOLDER OPTIONS Select FILE TYPES Locate the extention you want to change (ie. .jpg) Towards the bottom you will see "Opens With:" and a Change button. Click CHANGE Locate the app you want to use. Click OK Enjoy ! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) Or what Howard said works easy as well. |
736conver |
Thanks I knew there was an easy fix, just didnt have the time to play with it.
Lo-Fi Version | Time is now: 11th July 2025 - 01:02 PM |
