Minimum Front Rotor Thickness, What does the factory recommend |
vesnyder |
Nov 22 2005, 01:55 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I want to machine the braking surface on my current rotors and they measure out to 0.375 inches. What is the minimum thickness and can I have these done once more?
maf914 |
Nov 22 2005, 02:32 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Are you talking front or rear?
Per the Haynes manual: Front disks: New 0.433", Minimum 0.394" Rear disks: New 0.0.374", Minimum 0.35" |
Marlow |
Nov 22 2005, 03:46 PM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
I just replaced both front rotors on my 74 with new Zimmermans.
Old and new rotors were stamped with 8.5mm minimum (= 0.335 inches). See if your rotors are stamped with a minimum thickness. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:00 PM |
