| Brando |
Nov 25 2005, 10:48 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
It can be a pain getting ahold of rear droplinks (i'm having a pain).
Thinking about having adjustable droplinks made for less than OEM/Retail price. How many would be interested in adjustable rear droplinks with openings for stock bushing size? Let loose the flames and support. *puts on devo RAD suit* |
| Aaron Cox |
Nov 25 2005, 10:49 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
a question that is sure to be asked:
"Mr Brando, what good would adjustable droplinks do on a non adjustable rear bar?" |
| brer |
Nov 25 2005, 11:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
i'd take any droplinks at a reasonable cost. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
| Borderline |
Nov 26 2005, 12:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
Seems like adjustable drop links would be necessary if you are going to adjust corner wts. To spend all that time adjusting your ride height to get the corners balanced if you have to tweek the sway bar to install the drop links that would screw up the corner wts.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Bill |
| Trekkor |
Nov 26 2005, 12:37 AM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Tell me more, I'm listening. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Would they be mounted to the bar in such a way to allow adjusting firm/soft? KT |
| Jeroen |
Nov 26 2005, 07:18 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
if the price is right, I'm interested
| skline |
Nov 26 2005, 07:24 AM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I actually thought it was a good idea. It would give you at least some adjustment which is better than you have with a stock bar now. Plus the fact that you can get them for less. I am in for a set.
| Brando |
Nov 26 2005, 12:03 PM
heading to the shop monday (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
| SLITS |
Nov 26 2005, 12:11 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Mr A-aron Admin Budding Engineer...... No sway (anti-roll) bar is adjustable. Only the length of the arm and/or the drop links. I can see it's back to Tricycle 101 for you. Ssssssssssslits |
| Aaron Cox |
Nov 26 2005, 12:55 PM
adjustable - as in the length of the lever arn changes, by moving the drop link closer (STIFFER) or farther (softer) away from the pivot. with an adjustable bar, you need adjustable droplinks..... i wouldnt think you would need adjustablity with a fixed arm bar (like a stock rear bar), but someone mentioned cornerweighting... |
| Trekkor |
Nov 26 2005, 03:06 PM
They *all* are. It's the drop links and there abilty to slide on the "fixed arm bar" that makes them adustable. We had this discussion a year ago when Ira was looking for someone to test his adustable rear bar. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) A drop link with a mounting bracket that would allow you to slide the droplink on the bar would be fantastic. KT |
| Mueller |
Nov 26 2005, 03:42 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
eliminating the preload would be nice...ideally the with the car on a level surface it should have zero force differential between each end link, but due to tolerances and beat up chassis and parts, there is bound to have one side under stress instead of being neutral...good idea, just don't use those cheap McMaster-Carr hiem-joints.....I bougth a set of homemade front units at a swap meet and they started to wear out within a few hundred miles Aurorabearing makes top qualitiy stuff.......... |
| Aaron Cox |
Nov 26 2005, 03:54 PM
but the droplink mount onthe bar is not adjustable. we are talking ADJUSTABLE droplinks not adjustable droplink mounts.... so i said...without a "Moveable droplink attatchment point" on the bar, the only benefit of a height adjustable droplink is to eliminate preloading of the bar... quit bitching about techincalities... |
| Trekkor |
Nov 26 2005, 06:33 PM
| nebreitling |
Nov 26 2005, 06:38 PM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
i've actually been thinking about fabricating these on my own, so i'd be in for a quality set, brando.
after corner-weighting the car, i have some serious preload on the rear bar. (also thought about just cutting and welding it to shorten one side...) |
| Aaron Cox |
Nov 26 2005, 06:40 PM
cut in the middle, get a die and cut left and right hand threads on it, and make a female threaded middle piece.... basically mod the old dogbone into an adjustable length droplink |
| Trekkor |
Nov 26 2005, 06:49 PM
Yes. The drop link should feel loose and be twistable by hand with the car flat on the ground. KT |
| Brando |
Nov 29 2005, 12:13 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
I am having a set made this week. Picshores should come within a few days (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| Brad Roberts |
Nov 29 2005, 12:18 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I'll throw a wrench into all of this.. you only need to make one side adjustable. You dont need two.
B |
| Trekkor |
Nov 29 2005, 12:21 AM
He's right...
Lo-Fi Version | Time is now: 30th April 2026 - 09:29 AM |
