BatAc |
Member ![]() ![]() Group: Members Posts: 120 Joined: 9-July 04 From: seattle Member No.: 2,329 ![]() |
The big black casing of the CV joint after taking out the 4 12 star bolts; in the other two holes are there pins, hex bolts or star studed bolts keeping that piece on??? Need to disassmble 'cause the ball bearing cage broke when "ear" went............already have replaced the ear.........stuck at this point.........
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
dowel pins.
if you pull enough it might come off, otherwise use a screwdriver, try not to mark up the surfaces too much! |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Whack on it with a rubber mallet. Don't pry with a screwdriver unless it's really dire.
Lo-Fi Version | Time is now: 2nd July 2025 - 07:02 PM |
