| germaneighter |
Dec 6 2005, 02:11 PM
Member ![]() ![]() Group: Members Posts: 130 Joined: 9-August 05 From: Tulsa, OK Member No.: 4,563 |
What size options do I have in Fuchs 5 spoke that will fit stock fenders? What are the easiest to come by?
I will be re-drilling the 4 lug hubs. thanks |
| Porsche Rescue |
Dec 6 2005, 02:16 PM
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
6x15 will fit fine. The "shallow" 6's are about $5-600 for 4.
6x16 also fit and can sometimes be found for $400-500. 7x16 will likely require rolling/pulling the rear. In all cases 205 is as wide as you can go, sometimes only 195. Of course the 5.5x14's work easily (factory option wheel on 914-6). All are readily available on Ebay, thesamba.com and other places. |
| mskala |
Dec 6 2005, 02:41 PM
R ![]() ![]() ![]() Group: Members Posts: 1,935 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
Also 5.5x15 Fuchs are available and fit, although 6x15 is better for the 205 width tires.
| germaneighter |
Dec 6 2005, 05:13 PM
Are there different offsets for the 6 X 15 rim?
| SirAndy |
Dec 6 2005, 05:33 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,369 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yes and there's a chart that has been floating around many threads here that lists ALL Fuchs wheels ever made with offset and other specs and part # ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
| mskala |
Dec 6 2005, 05:39 PM
No, there's only one offset for 6x15 Fuchs, even though there
are 2 different types. There are 6x15 phone dials that are 52mm offset. And there are 6x15 cookie cutters that are same offset as Fuchs. |
| Porsche Rescue |
Dec 6 2005, 06:21 PM
This might help, if it is readable.........
Lo-Fi Version | Time is now: 7th December 2025 - 12:36 PM |
