carb timing? |
carb timing? |
Gearren |
Dec 7 2005, 06:00 PM
Member Group: Members Posts: 91 Joined: 18-July 04 From: New Bern, NC Member No.: 2,362 |
I have a 73 2.0 with webber 40's with the stock cam, and a bosch sport distributor, what is the proper timing with this set up?
Rouser |
Dec 7 2005, 06:37 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
What the heck is a Bosch sport distributor? Ignition timing remains the same whether it's FI or carbed: 27 degrees BTDC @ 3500 RPM. A little tricky, but doable. |
Aaron Cox |
Dec 7 2005, 06:38 PM
009 (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) |
Cap'n Krusty |
Dec 7 2005, 06:40 PM
30-32 degrees at full advance, which should be somewhere above 3000 RPM. You didn't say which distributor you have. Got a number for us? The Cap'n
Gearren |
Dec 7 2005, 06:44 PM
009
Cap'n Krusty |
Dec 7 2005, 07:02 PM
Dump it. Find something else. 050, 356 distributor, mallory, ANYTHING. The Cap'n
Dave_Darling |
Dec 7 2005, 08:25 PM
Or set it somewhere between 27 and 32 degrees BTDC at full advance. Should be all there by 3500 RPM. The timing will be over-advanced at idle.
Or set it at 5 BTDC at idle. It won't have enough advance at high RPMs. Or set it somewhere in the middle. Both ends will be off. The advance will come in all at once, no matter what you do. This is not the best distributor for our applications, unless you can re-curve it or find someone to re-curve it for you. --DD |
Lo-Fi Version | Time is now: 10th June 2024 - 08:41 AM |
