lazy hinge |
lazy hinge |
sk8kat1 |
Dec 14 2005, 11:06 AM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
the drivers side hinge on the hood seems to be lacking some of the stregnth of the passenger side ... it seems like I lift the hood and it then the one side droops a bit and seems to be supported butthe other side ...
is theis a spring adjst or a hinge replace ... does it make a differance if the spring is on a different notch than the other side ? mike |
smontanaro |
Dec 14 2005, 11:56 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
The notch position shouldn't matter, though that's only going to be a crude adjustment. I pulled
mine out to the third notch shortly after buying my /6. One of the common vendors has a hydraulic support conversion as well. Skip |
Lo-Fi Version | Time is now: 11th June 2024 - 02:11 AM |
