clutch operation help, sproing then cable is somewhat slack |
mskala |
Aug 22 2003, 05:35 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Maybe somebody can educate me on how the clutch is supposed
to be. While driving today, I felt something give when I pressed the clutch pedal, then it was still pulling (cable not broken) but didn't have the pedal travel to release all the way. Limp home, check back of cable, still fine not frayed. Check front of cable, not frayed. Higher free play than it was. Looked at front of tube while pressing pedal (tough to do!), tube not broken, also firewall tube not broken. When cable totally removed (looks good still), the release fork can be moved about 1 inch without any resistance. Can't see enough inside to tell anything. Should the release fork be movable (much)? Do I have to pull the trans to find out what's wrong? Thanks all. |
tryan |
Aug 22 2003, 05:48 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
plastic cup bushing?
edit.....a bird bath post had the actual pedal stamping break. trunion and clevis look okay? |
Curvie Roadlover |
Aug 22 2003, 05:54 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Sounds to me like a broken weld on the clutch tube in the center tunnel. (IMG:style_emoticons/default/sad.gif)
brant |
Aug 22 2003, 06:21 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
pull the pedal board and check the roll pin on the actual pedal
where the clutch pedal is attatched to the pedal shaft... some hand movement on the throw out fork is normal. let us know what it turns out to be. brant |
mskala |
Aug 22 2003, 06:29 PM
Thanks all so far. I'm going to look into these things
tonight. Hadn't thought of the pedal roll pin. |
Andyrew |
Aug 22 2003, 06:52 PM
(IMG:style_emoticons/default/agree.gif) With Curvie...
had the same problem with the same symptoms, I think its very common problem.. |
tryan |
Aug 22 2003, 07:01 PM
surgery. or as et would say .....ooouuuuuccch
Attached thumbnail(s) |
tryan |
Aug 22 2003, 07:09 PM
snagged from bird land. watch out for the fuel line.
mskala |
Aug 22 2003, 08:38 PM
Well, didn't see any problems with the pedal roll pin and from the light
I could get in there, no loss of the release fork bushing. Then I took the whole cable out, and where the metal sleeve ends at the firewall, cable is frayed bad. That end is sharp, but of course isn't supposed to be contacting the cable. I don't know how I did that, but unless I see something else, I'm going to get a new cable in and see. Thanks |
tryan |
Aug 22 2003, 09:03 PM
buy two (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 23rd May 2024 - 06:42 AM |
