Leaky Brake Master cylinder, Rubbers are supposed to keep you safe |
adammtb |
Dec 18 2005, 10:22 PM
Member Group: Members Posts: 68 Joined: 24-September 05 From: Asheville, NC Member No.: 4,856 |
So...we thought we were done and then noticed the very rusty brake master cylinder. Upon inspection the little rubber grommets? at the top of the cylinder (where the fluid tubes come in from the resevoir) are cracked and the source of the leak.
Can you replace just these stupid little rubber things or are they integrated into the cylinder and the whole assembly needs replacement? Help...Christmas is coming soon. |
URY914 |
Dec 18 2005, 10:26 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
If you buy a rebuild kit they come with it. But they are a major PITA to replace. If those are worn out so are the seals inside the MC. Buy a new MC. Almost as much work to replace the whole MC than it is to replace the grommets.
adammtb |
Dec 18 2005, 10:56 PM
I just found a NOS 914 master cyinder for $90 on Samba...see the link
link to master cylinder Is it sketchy to use NOS parts or is this a good deal? |
Lo-Fi Version | Time is now: 1st June 2024 - 09:11 AM |
