Rear spring rate |
Rear spring rate |
1bad914 |
Dec 28 2005, 07:07 AM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
Is there anyway to figure out what pound rating a set of rear springs are? The ones I'm looking at are thicker than stock by quite a bit, they are painted yellow. Just wondering.
ArtechnikA |
Dec 28 2005, 07:18 AM
coil spring rate:
D coil diameter d wire diameter n number of active coils |
Jeroen |
Dec 28 2005, 08:35 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
or just put some weight on them and measure the compression
KenH |
Dec 28 2005, 11:39 AM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Put one on a bathroom scale and add enough weight to compress it one inch - read the scale.
Ken |
Lo-Fi Version | Time is now: 11th June 2024 - 04:11 AM |
