> Random LT1 progress post, Replacement for the relay board
bondo
post Jan 12 2006, 03:42 PM
I rearranged the LT1 wiring harness to terminate at a plug with all the connections I need for the engine. This plug plugs into the 18 pin socket on the side of the box. Below that is an 8 pin socket for the trans (starter, reverse lights, trans cooler pump).
Replies(1 - 9)
bondo
post Jan 12 2006, 03:44 PM
On the other side is a power connector where the major current loads go in and out of the box. Above that is a socket for signal connections. (gauges, serial data, check engine light, etc.)
bondo
post Jan 12 2006, 03:46 PM
The inside has 6 relays, for switching everything controlled by the ECU, and one for the starter solenoid power. Everything is fused through that fuse panel in the center. The whole thing will mount about where the original relay board was.
Mueller
914 Freak!
looks good...what kind of connectors are those?
do they "lock"??
bondo
post Jan 12 2006, 03:48 PM
They're old school "Cinch Jones" connectors. While they do not lock, they do require substantial force to plug and unplug. I will make sure the wiring is not tugging on them in any way and it should be fine.
TonyAKAVW
post Jan 12 2006, 03:54 PM
That's my ride.
Very nicely done.... Except for the wire nuts. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
-Tony
bondo
post Jan 12 2006, 03:59 PM
Those aren't wire nuts! Those are crimps for joining many wires. I thought it was a better solution than trying to solder 4-5 wires onto a single connector pin, and I didn't have room for a terminal block.
fiid
post Jan 12 2006, 04:36 PM
Turbo Megasquirted Subaru Member
Wow. That looks like my wiring doesn't (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
That's a compliment (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
airsix
post Jan 12 2006, 05:36 PM
I have bees in my epiglotis
That looks super. Very nice work. Very nice.
-Ben M.
bondo
post Jan 12 2006, 09:11 PM
Thanks guys! I'm trying to make this as clean a conversion as possible. This has led to serious complication, as it won't be a clean install if I have to go in later and add/modify something that I forgot or changed my mind about. I'm having to consider everything from the ground up, and remember what I'm doing, and do it all in the right order. To do this I have had to clear some brain space by forgetting all of the STTNG episodes I had virtually memorized... But on the plus side I get to watch them again for the first time. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
- Lo-Fi Version Time is now: 3rd July 2025 - 04:48 PM
