Yoei66 |
My ride ![]() ![]() Group: Members Posts: 168 Joined: 28-February 05 From: Portland, OR Member No.: 3,682 ![]() |
I've put about 4000 miles on my 1.8 since I purchased & had the valves adjusted. Is it about time for another? How often do you adjust the valves on your 914-4's?
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
IIRC the recommended interval from Porsche is every 6k.
I think most people do it around 3k. |
ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
Every 3,000 miles without fail. That got drilled into me back in 1979 when I first got into VW maintenance and I've stuck by it. If VW or Porsche ever recommended anything else, I've never seen it. Now that I run synthetic oil I've changed the oil change interval to 6,000 miles, but the valves still get checked every 3,000 miles. There is so much that depends upon proper valve adjustment that I want to make sure they never out of adjustment.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,262 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I change my oil every 3000 miles, and check the valves every other oil change. The factory manual calls for 6000 mile valve adjusts.
--DD |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
6k, unless something odd happens.
b |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
I do exactly the same as Dave does, plus whenever it sounds like it could use a check.
M |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
can we now revisit the discussion about valve lash gap.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Every other AX or track event since I really don't rack up too many miles on the 914. Change the oil once in the summer and once in the spring...stuff is pretty cheap.
I set my valve lash to .004 to .005 and I am running the 911 swivel feet. (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
Allan |
With 1.7 rockers??? |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
I'm with Geoff, Hate the job but I run the piss out of my car. I keep the gaps close (snug .005 .007) also but I have tuned my ear to things that don't sound quite right.
Bleyseng |
Of couse! They don't fit on the later larger 10mm rockers. I am running SS valves and don't want any mushrooming as the swivelfeet are easier on the valve ends. Yep Joe, I run the piss outta it when we race. We (Blair and I) both AX and share the car so it can get freakin hot running 8 runs in a short time. It will be interesting to see how hot the oil gets now with the new Raby cam. I have seen 240+ several days of AXing which is too hot for my tastes. I have never seen much valve stretching on this engine, but I have seen it on other aircooled motors I have had. Checking the valve lash is a pain but much cheaper than head/engine rebuilding! I suspect Blairs Black 2.0L has a valve in the piston due to running the wrong MPS and a kid driving the piss outta it without watching his valve lash clearances. bad combo.... (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mgw.gif) |
hedfurst |
Member ![]() ![]() Group: Members Posts: 99 Joined: 9-March 03 From: S. Mississippi Member No.: 406 ![]() |
Chrome-moly pushrods, zero lash. Makes the adjustment EZ in the old 914! (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
dmenche914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 ![]() |
keep a record of the before and after cleanence. If you find over a period of time that one or more valves need bigger adjustments, then make you adjustment period more frequent, if you find a steady state over a period of time, it could be argued you can extend the adjustment cycle a bit. however thimgs can still suddenly change, so i would still go no more than 4-5 k miles. I generally hit the valves at 3-4 k miles, more often on my cars that tend to have the clearnace change faster, less on cars that are more stable, but do NOT neglect it. Engine damage can result, poor perfomance etc... Let them completely go, and you can trash the motor fast.
again a record of what they are before each adjustment is a good thing to keep It will give you a heads up if things are starting to go bad (ie time for a valve job) good luck |
mikelsr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region ![]() |
Thanks for sharing your knowledge. I hadn't thought of it that way. |
Joe Ricard |
Interesting oil temp observation. I only see 195 to 220 after 2 drivers barely taking enough time to change numbers, 12 runs total check tire temp and get back in line. ooutside air temp about 98 degrees black top enough to cook an egg. Then we did about 10 fun runs each.
I only get 230 on the oil temp driving home same day. about 90 MPH. |
Lo-Fi Version | Time is now: 22nd September 2025 - 10:34 PM |
